Ironhead A place to talk about Ironheads.
Best Performance Mods for an Ironhead?
Old Aug 11, 2008 | 07:09 PM
hardcore69's Avatar
hardcore69
After seeing the pic I have to say "what a waste of a good Ironhead". That thing ain't gonna handle for sh*t, so why worry about HP. It's just a show bike.
Old Aug 12, 2008 | 07:30 PM
Mario77746's Avatar
Mario77746
To each his own man....and by the way, it's not a show bike by any means. I've been riding this bike every day and intend to do the same in the future. I'm already use to it and can throw it around pretty good now.
Why worry about HP??? Come on now. Anyone with any experience want's the power there when they feel like giving it some juice, straight line or in the curves. Of course this will be straight line.....
Old Aug 13, 2008 | 10:35 PM
jtmon75's Avatar
jtmon75
mario,i think your bike looks cool,when you ride you should be proud.real bikers don't put down other bikes,they respect them.the fact remains you are on two wheels!!!
Old Aug 15, 2008 | 03:58 PM
SportsterBob's Avatar
SportsterBob
[QUOTE=Mario77746;3716556]Thanks for the replies all. So far I'm sold on the performance aspect of it. Now, $$$.... How much are we talking to get this up to 80hp / 70tq range? I know everyone is different but a good guesstimate would help. By the way, it's a 76 sporty driveline...Thanks.
Best to do the mods in stages....Easier on the pocket. Get your heads ported, aftermarket cams and valve springs to match the cams. If possible, get a pair of used heads and get them ported so you won't have down time. Ironhead heads are on e-bay for pretty good prices. The porting work done at first can be used later if you decide to go stroker.
I'll go out on a limb and estimate $600 for head porting....Jerry Branch on the West Coast is in my opinion one of the best. You can probably find cheaper prices elsewhere but stick to those who already know the game.
Old Aug 15, 2008 | 04:12 PM
SportsterBob
I forgot to ask........Who made the frame? Looks pretty sturdy. At least 1" backbone tubing and single downtubing to the motor mounts. Definitely not the spindly work with bolt-on hardware. And some serious rake to boot!.....you got a show-bike already! Consider entering it into bike shows. The frame alone will attrack some seroius attention! You don't see many sharp looking Ironheads out there anymore!
Keep The Faith!!!!!!!
Old Aug 15, 2008 | 07:54 PM
Mario77746's Avatar
Mario77746
Thanks. The frame is a redneck eng. It's 4 up 5 out with a 250 rear.
I already have a S&S E carb on it with a Billy Lane velocity stack. The motor already has Crane Single Fire ignition and drag pipes (no baffles).
My first concern is driveability. I'm sputtering like hell at mid throttle from 50mph up. Absolutely no problems starting. Driving from 0-40mph in 1st - 3rd is no problem. Once I hit 4th I have to either barely crack the throttle or go full throttle for it to run. Anything else and it just spit and spudders. Any advice on what jet sizes I should be around?
After that is fixed, I'm thinking the next mod will be a cam. Which one should I go with? I know head work and upgraded higher comp pistons, maybe even a stroker kit will be in the works in the future. With this in mind, I still need a streetability...I'm not one to let my bikes collect dust in the garage.....
Old Aug 15, 2008 | 08:33 PM
SportsterBob
With your sputtering, read your plugs. That is the ONLY barometer you have to see what's going on in the cumbustion chamber.....For a 61", I run a .68 main jet....If it spits and hiccups thru the card throat, it's too lean. If it "blubbers" thru the exhaust it's too rich. Sounds like your intermediate jet is OK. If it's sputtering at WOT in 4th, it's hard to determine right away if it's lean or rich......It could also be the the accelerator pump adjustment....Unknown at this point. If possible, take it up to speed where the sputtering occurs and immediately pull it off the road and do a spark plug read...If the plug is black and sooty, it's rich.....If it's whitish or very light light gray, it's lean. Dialing in a carb is a "one step at a time" chore......Don't make more than one change at a time to get it dialed in!
Old Aug 15, 2008 | 08:54 PM
SportsterBob
H-D used to produce a PB cam set but that was for the 900 Sporty with the Timer/Magneto sticking up out of the cam cover......Andrews still produces cams for the 61" but they aren't cheap new....about $400/set....You can still find some used sets on e-bay but always proceed with caution...always do a search on the seller. Andrews has a "Y" grind set that has .425" lift that will do fine with stock stroke/bore....There is a more radical profile available like the "R5" for modified stock bore/stroke and small stroker at .445" lift. J&P is one distributor that carries Andrews cams but their markup is pretty steep for Ironhead Cams.
Focus first on getting rid of your "Flat Spot" before going further......You may be happy with what you got once that flat spot is gone!
Old Aug 15, 2008 | 11:34 PM
xxxflhrci's Avatar
xxxflhrci
IMO, building up a 30+ Ironhead is only asking for trouble. The cases are weaker than EVO cases and are now antiques. You can build it and I guess ride it reasonalby and get by. But, if you beat it, don't be surprise when the bottom end of the cases blows out.
Old Aug 16, 2008 | 12:14 PM
Mario77746's Avatar
Mario77746
Ok, the bike was put on a dyno and the air/fuel came back at 11/1 mid range. I have a 26 intm jet and a 68 main jet. Again, the internals are stock. I have straight pipes, crane single fire ign and a velocity stack. Where do I go from here other than getting a CV carb for now????
