Ironhead A place to talk about Ironheads.
cam timing
Old Sep 6, 2008 | 03:26 PM
pyro's Avatar
pyro
Default cam timing
manuals don't say specifically so I just wanted to check... cams are timed with the front cylinder timing mark in the window?
Rich
Old Sep 6, 2008 | 03:32 PM
FilthyLucre's Avatar
FilthyLucre
Doesn't matter, line up with the mark on the pinion gear.
Old Sep 6, 2008 | 04:05 PM
pyro's Avatar
pyro
I was hoping to say nevermind before someone posted. Allready figured out and back together. Sometimes I impress myself, other times I have to ask myself "WTF were you thinking". This time was the latter. Thanks for the swift response though.
Rich
Old Sep 7, 2008 | 10:17 AM
popstheoldman's Avatar
popstheoldman
yea put timin mark dead center in insp. hole then align the marks on cams and pinion gear exactly sounds like u got itdoes it fire up? hers another trick if you have o ring manifold and want to seal so u have no leaks and bullet prof. get black electritions tape the kind thats viynal backed put 2 wraps around the the joints over the o ring then relpace clamps it will never leak thats one headache u wont have to deal with works great i should charge for this info juno ha ha ha ha
ride hard die fee
Old Sep 7, 2008 | 09:14 PM
piniongear's Avatar
piniongear
Feel free to charge for your information if you like, but to do cam timing you are not required to align the timing mark dead center in the hole.
That is done when you want to time the oil pump breather.
But then, I am sure you know that........pg
Old Sep 8, 2008 | 06:06 PM
popstheoldman
well from what i under stand if u dont do it the way i explained u get pressure build up in cases and causes leaks or other problemms like blowin gaskets and such
Old Sep 8, 2008 | 06:40 PM
piniongear's Avatar
piniongear
Yep, when you have had an engine apart, or at least had the oil pump removed, the first thing you do is:
Insert the pump.
Then move the flywheel to show the mark in the hole. This positions the crank in the position you need to obtain proper timing of the pump breather.
Next is to make sure the small hole in the breather tube lines up with the notch. Now we are finished timing the breather.
After that, the timing mark is ignored. In fact it moves away from the hole when you do the next step.....which is timing the cams to the pinion gear.
I guess the timing mark exercise is better stated as the step to set the breather timing correct before you move on to the cam timing. Of course that is done by lining up the mark on the pinion mark with the cam closest to it and then the other cams follow.
Lining up the pinion mark requires moving the flywheel.... and I find some people become confused because they think the timing mark has to stay at the hole when you time cams. Timing mark in the hole is just not part of timing the cams, it is for timing the breather..........pg
Old Sep 9, 2008 | 11:52 PM
sepixlh's Avatar
sepixlh
Yes right (as usual) , if you have removed pinion gear from crank notice that you can put it back correct way. It can be installed at least 2 ways and only one is correct.
Affe has done some research about timing breather:
http://www.saunalahti.fi/~affe2/hdlo...tml#1150288340
Old Sep 10, 2008 | 09:11 PM
eglideic's Avatar
eglideic
Default Cam timing.
That mark is only for setting the points.
peter foster
Feb 25, 2019 07:42 PM
WP50
EVO
May 5, 2015 05:34 AM
Satch
Ironhead
Apr 15, 2008 02:02 PM
dph1107
Exhaust System Topics
Jul 9, 2007 02:43 PM
Denis
May 17, 2007 11:27 PM
