Ironhead A place to talk about Ironheads.
Fluid types and specs.
Old Sep 27, 2008 | 07:53 AM
customsoftail200's Avatar
customsoftail200
Default Fluid types and specs.
Does anyone know what type and how much oil is supposed to go in oil tank and primary ofan old 75 iron head sporty??
Old Sep 27, 2008 | 08:02 AM
supr2nr's Avatar
supr2nr
If you have a 75 XLH with a side oil tank. It holds 3 qts. The primary holds 1.5 pints.
I use and most other people will agree straight 50W oil. The only brand of it I can find around here is Valvoline Racing 50W oil. Best oil for it. Us it in the primary and the oil tank.
Old Sep 27, 2008 | 11:47 AM
HDSmurph's Avatar
HDSmurph
28 Oz. straight 50WT or 60
Old Oct 5, 2008 | 08:44 PM
Broken Leg Rider's Avatar
Broken Leg Rider
The manual for the 79 XLH says to use 40 Weight in the gearbox and the following in the engine:
Medium Heavy grade 75 above 40F ambient.
Special Light grade 58 Below 40F.
Regular Heavy grade 105 ambient over 90F.
I don't know what weights the grades represent, but these oils are still available at the dealership.
I am using 20/50 Valvoline Max Life Synthetic Blend, which has been working well so far, in an 85F ambient. 40 in the trans just like it says.
Old Oct 10, 2008 | 05:05 AM
Hopper's Avatar
Hopper
I use straight 50w Harley oil in the engine, 60w in summer. (Hot here)
Harley Transmission Forumla Plus works good in the trans/primary for me. I have had clutch slip with some other oils. Too many anti-friction additives maybe.
300sd1982
EVO
Jun 21, 2017 08:48 PM
90FLHS
Oil Archive (no new posts)
Oct 1, 2013 10:12 PM
customsoftail200
Ironhead
Sep 27, 2008 08:02 AM
texfatboy
Apr 3, 2007 02:49 AM
riles10
Mar 2, 2007 09:56 PM
