Ironhead A place to talk about Ironheads.
Crank vent?
Old Jan 16, 2009 | 05:35 PM
tackleberry's Avatar
tackleberry
Thanks again for your replies, much appreciated.
Old Jan 16, 2009 | 10:33 PM
IronMick's Avatar
IronMick
Here are some pics of the 77/78 foofoo valve. First shows it installed but without the tube attached yet [not on my bike]; second shows the parts. The small part is the actual valve that fits inside the unit.
I installed one of these on my 1980 to get additional case venting. It was a tedious install as the '80 has a 1/8 NPT fitting down there and as you can see in the pic the foofoo is much larger than that - i started with a 1/8 NPT 45` fitting [to get around my forward controls] and worked from there.
I did notice that the engine sounded and felt like it was running much more freely, and acceleration seemed more quick, with the extra vent.
Old Jan 16, 2009 | 11:16 PM
piniongear's Avatar
piniongear
Hmmm, it must be some kind of wafer check valve. The metal tube looks just like the old tube used before this valve was added. Interesting.....pg
Old Jan 17, 2009 | 08:03 AM
98glider's Avatar
98glider
I have a 84 early with a gen. and mine is just vented to the air towards the back and towards the back sprocket and down towards the ground . Should I put a breather on it or just leave it alone. thanks
Old Jan 17, 2009 | 09:40 PM
IronMick's Avatar
IronMick
Stock it has the foofoo valve inside the gearcase cover, and was vented into the air cleaner. The suction from the air cleaner would increase the efficiency of the venting process, i assume but i do not know if this is significant.
You should not put a breather on that line as it has the one internally. You might consider running the hose into the air cleaner - wait for other opinions on this tho.
Moon Wolf
Ironhead
18
Sep 9, 2012 08:25 PM
mustangwagz
Ironhead
30
Sep 20, 2010 02:57 PM
jtbredneck351
Ironhead
21
Oct 9, 2009 09:29 AM
HDSmurph
Ironhead
Feb 8, 2009 09:30 PM
lewzab
Ironhead
Dec 10, 2008 12:37 PM
