Ironhead A place to talk about Ironheads.
H-D "PB" cams
Old Feb 20, 2009 | 01:21 PM
gunnut1's Avatar
gunnut1
Default H-D "PB" cams
This is probably a question for someone like "Pinionhead", up until 1971 Sportsters came with what they called "P" cams in them. One of the things that was done to make them go faster was to put in the H-D "PB" cams. Does anyone have any information such as timing/lift specs, etc on these two?
Old Feb 20, 2009 | 01:26 PM
IronMick's Avatar
IronMick
I "have heard" that the Andrews PB+ cams are "the same as" the original HD PB cams. It seems to me that i also have heard that there is a minor improvement, hence the + on the end of the tag. You could check the Andrews web site for specs for the PB+.
http://www.andrewsproducts.com/
Old Feb 20, 2009 | 07:45 PM
piniongear's Avatar
piniongear
I think I resent that! Ha-Ha..... probably a fair description though.
Let's shorten it to simply 'pinhead'
Regarding the cam question.......... Yes the P cams were standard issue for a number of years. I do not have the info on the PB cam lift or duration, so I cannot say anything about them except this......
I remember the cams coming out and they were no power increase over the P cams. If they had been you can bet I would have had two sets of them........ one in the engine and the other set as a spare sitting in the toolbox.
My recollection was they were made to operate better in a lower rpm range but that did not convey more power. Just an old man's recollection.
If you can find the lift and duration of the P and the PB it will tell you the difference and which is the better choice for the kind of riding you do........... pg
Old Feb 20, 2009 | 08:07 PM
shepdog's Avatar
shepdog
andrews web sight does not show specs for p cams but the pb cam looks like it is for 71-85 .410 lift and 295 duration at .20
Old Feb 21, 2009 | 09:04 AM
eglideic's Avatar
eglideic
Default Sportster P and PB Cams
My guess is that it only has to do with going from the distrbutor stcking up near the pushrods to the points and timing plate on the side near the shifter.
Old Feb 25, 2009 | 01:42 AM
sepixlh's Avatar
sepixlh
Andrews has a spec for these cams:
http://www.andrewsproducts.com/motor...SC_Cams_IH.htm
HD Stock Q (76-85) 10/32 35/7 lift 0.40 0.40
HD Power P (71-85) 30/40 40/30 lift 0.40 0.40
Andrews PB+ 34/40 43/31 lift 0.40 0.41
So PB+ has little agressive timing and in exhaust lift than P but not so much.
Old Feb 26, 2009 | 06:50 PM
scottericsonon's Avatar
scottericsonon
would these be any upgrade for a 1975XLCH??
which cams come in the 75s?
i know the 75+ had the "Q" cams but which ones were in the 75?
thanx
scott
lazye
Nov 6, 2013 04:36 PM
chamokie
Jul 31, 2012 06:53 AM
GEORGEW
Jun 16, 2010 02:07 PM
Sallyman
May 21, 2010 12:09 AM
Johneb48
Exhaust System Topics
Jul 27, 2009 08:31 PM
