Ironhead A place to talk about Ironheads.
85 Ironhead
Old Mar 28, 2009 | 10:14 AM
IronMick's Avatar
IronMick
Adjusting the pushrods is a do-it-yourself job. Follow the steps in the manual.
It is important that they be not too tight. For the exhausts, adjust them finger tight so that you cannot rotate the pushrod with your fingers, then loosen just enough so that you can, then loosen "1 side" more. Same for the intakes but loosen "1/2 side" more instead of "1 side" more. "Side" refers to a side of the six sided adjuster.
Ask questions at each stage:
1: remove anything that is in the way
2. Pop out the keepers with a flatblade screwdriver
3. lift up the covers and secure them with a length of solder wire or household electrical wire or whatever [coat hanger is too stiff]
4. You need 1/2" and 7/16" open end wrenches
5. Spark plugs out, rear wheel off the ground, shift to 4th gear
6. rotate the engine with the rear wheel; adjust a pushrod when the corresponding one on the opposite cylinder is up [<-- error corrected!]
7. when you final tighten the lock nut do not overdo it out of fear that it will come loose; it is a locknut, it will not come loose; 10 ft lbs [firm plus a little more] will do it.
Old Mar 28, 2009 | 10:29 AM
piniongear's Avatar
piniongear
Exclamation
6. rotate the engine with the rear wheel; adjust a pushrod when the corresponding one on the opposite cylinder is down
Mick......
A small correction there.
You adjust a pushrod when the opposite like pushrod is at it's highest point, not the lowest point.
F
or example, if you want to adjust the rear intake the front intake must be at it's highest point ( front intake valve fully open).
Now you can adjust the rear intake valve which is fully down (valve completely closed)
You know what I'm saying, but your words just got switched around....... pg
Old Mar 28, 2009 | 01:53 PM
IronMick's Avatar
IronMick
[SIZE=3][FONT=Comic Sans MS]Mick......
You adjust a pushrod when the opposite like pushrod is at it's highest point, not the lowest point...
Oops, you are right. Thanx. I just got it reversed. I went back and fixed it.
Old Mar 30, 2009 | 10:18 AM
83XLX's Avatar
83XLX
Originally Posted by IronMick
...It is important that they be not too tight. For the exhausts, adjust them finger tight so that you cannot rotate the pushrod with your fingers, then loosen just enough so that you can, then loosen "1 side" more. Same for the intakes but loosen "1/2 side" more instead of "1 side" more. "Side" refers to a side of the six sided adjuster...
Great advice on setting the exhaust valve a little "loose". That's the way I do it, too.
jstanfield1@una.edu
Jun 22, 2016 08:41 PM
baka1969
Apr 21, 2012 08:12 AM
naildriver29190
Mar 20, 2012 11:00 PM
Venompwr2
Ironhead
Dec 12, 2011 07:01 PM
heavyCruiser
Ironhead
23
Sep 15, 2008 10:07 AM
