Ironhead A place to talk about Ironheads.
brake light switch.....
Old May 5, 2006 | 08:18 PM
Hey Zeus's Avatar
Hey Zeus
Default brake light switch.....
I am in my finishing stages of rebuilding my basket case.....I am not familiar with these Irons, as I have said in the past so try and humor me. I am trying to figure out exactly how of where the rear brake light switch goes on this bike. I have a right side shift and I don't see any type of switch in my boxes of nuts and bolts here. Please advise and thank you in advance.
Old May 5, 2006 | 09:57 PM
pococj's Avatar
pococj
Default RE: brake light switch.....
It works off the rod that operates the rear brake. The switch mounts on the swingarm, and a tab that pushes on it mounts on the rod. See if piniongear can get a pic of his for you. It ain't in any of the books I have, 1959 - 1982.
Old May 6, 2006 | 12:25 AM
wwaarrppeedd's Avatar
wwaarrppeedd
6th Gear
heres a pic i have i think its a '73 when i put my bike togehter i could find how the stock switch went and wired in a universal switch........then i found out later........
[IMG]local://upfiles/10420/74F5EE62D7854C5BAB76CE26B0767E23.jpg[/IMG]
Old May 6, 2006 | 11:09 AM
Hey Zeus's Avatar
Hey Zeus
Thanks for the input....I appreciate it. This switch looks pretty universal. I'll keep my eyes open for one.
Old May 6, 2006 | 01:55 PM
piniongear's Avatar
piniongear
If you live in Ohio there should be some HD dealers in your area that cater (somewhat anyway) to older machines. In anycase a dealer should be able to easily order one for you. It is just a spring loaded switch that clamps around the brake rod as pococj described. The switch is positioned on the rod with the spring compressed against that tab on the s/arm. Press the brake pedal and the switch moves away from the tab, causing the stop light to go on. I have no catalog info on this switch as there is only mention of it in the factory manual stating a mechanical, normally closed, plunger type switch, parts of which are not available. The switch must be replaced as a unit......piniongear
Old May 8, 2006 | 11:53 AM
Calwoodbutcher's Avatar
Calwoodbutcher
Jireh part number 17-58 it's $8.95
dmcclain
Aug 12, 2019 10:26 AM
Bluraven
Jul 4, 2015 12:21 AM
joe1958
General Topics/Tech Tips
Feb 25, 2013 09:17 AM
section8joe
Jun 2, 2010 10:41 PM
pistole
EVO
Feb 8, 2010 06:20 AM
