81 XL issues
1. Every now and then she wont up shift to 4th, and go into neutral from 3rd instead. She also has problems from first to second, getting stuck at neutral sometimes, and I have to downshift back to 1 to try again to hit 2.
- Previous work done:
I replaced clutch basket, plates and all, springs, and clutch cable, adjusted chain tensioner, added proper oil, replaced gasket.
2. I have some issues with my wiring. The bike came wired up like a birds nest, and i havent added anything other than a new head light, tail light, and brake light switch for the front brake lever to the old wiring scheme. It never fails that when i leave the house with 15 good volts in the battery, i always come back with less than 12. I dont hit many stoplights, and avoid stops for gas as much as possible to save battery life. Once i left with 13+ and made one stop for gas, and another at the hardware store. Bike wouldnt start at the store when i left. Im thinking a loose wiring scheme or a poor generator.
I added a new set of controls to the bike, complete with buttons for horn, blinkers, on/off, high/low, horn, etc.... but have only wired up the new headlight and the brake light switch. The rest are unused until the rest of the parts come in. I also replaced the old custom LED tailight board with a new lamp, dual contact led bulbs, one for running, the other activates when a pressure switch is pressed, all parts are 12v rated.
3. This bike did not come with an oil filter, not sure how its still running, but it is. The frame is an old Paugcho frame, and i have no idea where to begin to locate a custom oil filter kit that will suffice. Any suggestions are appreciated.
Kits are commonly available. Any inde motorcycle shop can order one in. Or go to any of the catalog companies such as J&P Cycles www.jpcycles.com or eBay.
I forgot to mention one bit of critical info, the engine sits on the frame such that the oil drain plug is blocked by a supporting bar of the frame, so I cant drain the engine at its lowest point. I pulled the oil line from the pump, drained the tank that way, ran some seafoam through the system to clean it up a bit, drained it again, and topped it off. If this beast doesnt need a filter, I will forgo the purchase, but my suspicions tell me that there is a bunch of gunk sitting in the bottom of the engine case.
Engine oil in oil tank with drain plug. Primary oil in case with a different drain plug - on the left side, bottom, near jiffy stand mount.
Anyone know where I can get a deal on an inline voltage gauge. I am thinking the voltage problem lies in the generator, or the parts I have added. I bought a cheap little continuity reader (connect to both ends of a wire and a light will illuminate if there is current) and used it on each battery cable with the power turned off. It didnt light up so i assume there is no voltage bleed. I guess there still could be some bleed with the power on, but that might take years for me to single out which splice is faulty.
Concerns-
1. the equipment I added to the wiring scheme is pulling too fast for the generator to keep up (added a new headlight, and led tail lights, brand new HD gell cell)
2. the generator is on its way out the door and needs to be replaced
3. a combination of the two listed above
I assume the generator only kicks in at a certain RPM, and only when I'm in gear, am I way off? Is there anything obvious that I'm not considering?
DV
The factory manual contains a series of tests that you can do with the generator. FM available from HD dealer [most $s], catalog companies like J&P Cycles, various eBay sellers [least $s]. Get a parts book also.
Gen is a simple device - easy to remove, dismantle, clean up, put back together. It will be filthy inside. Clean up with spray can electrical contacts cleaner.
The gen puts out 10 amps. This is enough for the headlite, the ignition system, the usual lighting, and perhaps a couple amps extra - not much extra. You should be OK with what you have on there.
