Ironhead A place to talk about Ironheads.
roadway873
Old Apr 29, 2009 | 12:14 PM
roadway873's Avatar
roadway873
Cool roadway873
Just bought a 76 ironhead sportster, lots not right with this bike but I would like to correct everything, just as soon as th money allows, so here are a few basic ?'s I need answers to like what is the correct oil to run in sump/crankcase. Also what are the proper plugs for this bike, next, if someone put straight pipes on it without rejetting the carb will it do harm. Last but not least, what about tranny fluid, if different from crank oil. I have a manual on the way but am doing research in the meantime,any help weould be appreciated. ps-cylinders need repainting also, can I use any good flat black heat resistant paint------------HELP!!!!!!!!!!
Old Apr 29, 2009 | 08:59 PM
IronMick's Avatar
IronMick
Originally Posted by roadway873
1. what is the correct oil to run in sump/crankcase.
2. Also what are the proper plugs for this bike
3. ... if someone put straight pipes on it without rejetting the carb will it do harm.
4. ... what about tranny fluid, if different from crank oil.
5. ... cylinders need repainting also, can I use any good flat black heat resistant paint ...
1. HD Formula+. This is a new synthetic that replaces SportTrans. There are lots of other choices but this is a good one.
2. NGK BPR 6HS
3. Probably not. The pilot screw may need to be adjusted to run a little richer. If the plugs are too white looking and/or if there is a backfire rap when you let off the throttle then richening up the pilot screw setting is the solution.
4. Tranny fluid and crank oil are the same thing. Ther are two oils, one for the engine in the oil tank and the other in the primary for the primary chain, trans, etc.
5. Many guys use BBQ paint. Any automotive engine paint marked on the label for 1200`F or higher will do. The 1500`F and 1600`F paints have more difficult application instructions.
If it says engine paint but does not give a temperature or says about 600`F then it will burn off quickly around the exhaust ports and between the fins - regardless of what the counter guy might say. This paint is only for liquid cooled engines.
Old Apr 29, 2009 | 10:43 PM
roadway873's Avatar
roadway873
Thanks for the info-big help, will know more when I get my manual-do you know of good spots online to buy parts-hopefully cheap!!!!!!!!!!!!!!!!
Old Apr 29, 2009 | 11:43 PM
sepixlh's Avatar
sepixlh
1. Crankcase/sump oil= motoroil I have used 20W-50 warm conditions 50W or 60W
2. Champion H8C, Nippondenso W16LS, Harley Davidson R4 or NGK as Mike wrote.
3. Readjusting carb is thing that you must do, straight pipes isn't good option.
4. In primary/transmission there should be Sportster Transmission Fluid.
5. Zink based primer and normal paint holds nicely..
Old Apr 29, 2009 | 11:52 PM
roadway873's Avatar
roadway873
thanks--------keep pumping the info-I need it!!!!!!!!!!!
Old Apr 30, 2009 | 07:39 AM
IronMick's Avatar
IronMick
Tell me more about this one - new for me. Is the zinc primer an automotive product? Do you mean normal engine paint? Whatever?
Old Apr 30, 2009 | 05:17 PM
shepdog's Avatar
shepdog
we use a zinc base primer on our bridges we build, would not think that it would cover very nice with automotive paint, ours goes on very thick.
Old Apr 30, 2009 | 07:43 PM
sugarplum247's Avatar
sugarplum247
you can go on line to jerehs and jpcycles and request free cataloges they have everything
Old Apr 30, 2009 | 07:50 PM
sugarplum247
http://www.jirehcycles.com/
RezDuane
Oil Archive (no new posts)
Feb 21, 2019 04:32 PM
crazymjb
Jun 25, 2014 12:49 PM
BradP1987
Aug 25, 2013 12:10 PM
raksasas
Nov 20, 2009 07:49 PM
kidcrappr
Sep 20, 2007 11:45 AM
