Ironhead A place to talk about Ironheads.
Points
Old May 8, 2009 | 02:39 PM
sportster77's Avatar
sportster77
Default Points
My 1977 sportster is not making a spark at the points when they open. what might be wrong. The cam sleeve is spinning ok, not stripped.
Condenser ? Ignition coil ?
Old May 8, 2009 | 06:08 PM
straydog13's Avatar
straydog13
are you getting juice at your coil?
Old May 8, 2009 | 08:51 PM
sugarplum247's Avatar
sugarplum247
turn engine over til points are open check with test light see if you have power there or not(at the points)
Old May 9, 2009 | 01:18 PM
hillbilly470's Avatar
hillbilly470
If you dont have any fire to the coil,in or out ?
Old May 9, 2009 | 01:19 PM
hillbilly470
I have a 80 ironhead and in need of some parts if anybody has some. thanks
Old May 10, 2009 | 08:14 AM
sportster77
I know the 12 volts comes and goes at the coil or points. I have 12 volts at the rocker kill switch when the ignition is on so now I've got to check continuity in each of the wires leading to the coil and the points. One of them is faulty. Will post again when it's found.
Old May 10, 2009 | 11:46 PM
sepixlh's Avatar
sepixlh
Ignition is "routed" ignition switch -> run/stop switch -> coil "positive" -> coil "negative" -> points -> ground. So when points are closed they ground that "negative" end of coil.
Bcoish
EVO
11
Apr 29, 2019 09:09 PM
Three eagles
Oct 3, 2017 03:15 PM
RobertKing
Ironhead
Apr 6, 2017 07:02 AM
forest2
Jul 3, 2008 07:41 AM
zoorider
Jun 22, 2006 07:32 PM
