Ironhead A place to talk about Ironheads.
Timing question.
Old Apr 19, 2017 | 10:31 AM
Basket case's Avatar
Basket case
Stage II
I don't want to high jack your thread. But I have similar problems. I have a 1970 ironhead with the distributor styl points set up. Will only run a few seconds at a time. And hard to get started at all. Is kick start only. Any advice?
Old Apr 19, 2017 | 11:24 AM
IronMick's Avatar
IronMick
If it does run for a few seconds then it is getting spark, and is probably running on just the fuel in the combustion chamber. I would check the fuel in the tank [is it fresh?], and the fuel path from the tank to the carb [dismantle, clean, inspect the petcock, the fuel filter, and the fuel line].
To refurbish the petcock you will have to empty the tank and remove the petcock. A good opportunity to clean and inspect the tank [remove the accumulated crud at the bottom] and install fresh gas.
Once you are confident in this part and see how it runs we can go on to what it needs next.
Old Apr 19, 2017 | 11:48 AM
72 Ironhead XLH's Avatar
72 Ironhead XLH
Try this with points. set your gap at .018 on the sharp front lobe, double check gap on the wide lobe. Set the weights in the advance position .I use a O ring between the bolt and lobe plate and turn it CW to advance the weights.friction holds the weights advanced
Get motor on #1 compression stroke and locate the vertical line in the inspection hole. Insert a piece of cig paper between the points with the points closed ,rotate plate CW if necessary.
Now, rotate the plate CCW untill the cig just slides out, lock the plate down, remove the O ring and reinstall bolt
Go riding
Old Apr 19, 2017 | 07:37 PM
hell hound's Avatar
hell hound
I know this is not what your asking, but the best thing I ever did to my ironhead was install an ultima electronic ignition and coil
night and day difference
Old Apr 19, 2017 | 07:49 PM
IronMick's Avatar
IronMick
+1
AmericanNightmare73
Ironhead
Feb 27, 2012 12:29 AM
rkadish
Ironhead
Oct 26, 2009 02:19 PM
craezlarry
Ironhead
Jul 21, 2009 08:40 PM
AmericanNightmare73
Ironhead
29
Jun 2, 2009 02:47 PM
sugarplum247
Ironhead
Apr 3, 2009 09:08 PM
