Ironhead A place to talk about Ironheads.
71 ironhead oil change
Old Aug 23, 2009 | 10:32 AM
lagunatic's Avatar
lagunatic
Default 71 ironhead oil change
I have not received my manual yet and know this sounds like a simple thing but I have found out by not knowing what your doing on a ironhead can have some very negative effects,so could someone give me a step by step on changeing the oil. Iam planing on useing 60 just need to know where to drain where to put in, how much and any other knowledge you guys would like to throw in there .I have rode this bike a little around town and I love the ironhead.just want to make sure Iam good on the oil.PG I will post pics as soon as I can find cord for my camara...thanks for all the help..
Old Aug 23, 2009 | 11:08 AM
IronMick's Avatar
IronMick
There are two oils to change, the engine oil and the primary oil.
The primary drain is on the bottom of the case in the side stand attachment area. Add it thru the primary chain inspection hole [top big plug]; it takes 1.5 pints [24 fl oz], or until it drips out of the overflow hole shown in this pic with the bike level [support it so that it does not tip over, eh] ...
The engine oil takes 3 quarts. Someone else will chime in on where the drain is on that oil tank.
Old Aug 23, 2009 | 12:45 PM
lagunatic's Avatar
lagunatic
Default 71 oil change
engine oil tank is aftermarket,raparound battery style if there is no drain can I just pump it out???????? thanks for the pic Mike
Old Aug 23, 2009 | 01:10 PM
IronMick's Avatar
IronMick
A convenient way to pump it out is with a drill pump - attached to a cordless drill. Available at Princess Auto, Harbor Freight, etc.
Old Aug 23, 2009 | 02:41 PM
lagunatic's Avatar
lagunatic
Default glitter in oil
I changed primary and their was glitery very very fine metal trace in oil and a small glob on drain plug nepple is this normal or time to worry. when I bought the bike the owener told be that the trans had been rebuilt with all new parts and at one of the best shops in Dallas area,Browns cycle .I have built alot of 4strokes for alcohol modifieds and have had this at brake in but this is a whole other beast.has anyone seen this????? you where right on the button Ironmick 24 oz.
deadanal
Oil Archive (no new posts)
Aug 29, 2012 10:19 PM
crazyeight
Apr 14, 2010 09:45 AM
rustyironhead
Ironhead
Mar 6, 2008 06:57 AM
texfatboy
Apr 3, 2007 02:49 AM
ZX2BY2U
Sep 1, 2005 08:16 AM
