Ironhead A place to talk about Ironheads.
BackFiring Help
Old Nov 6, 2009 | 04:33 AM
1979Sportster's Avatar
1979Sportster
2nd Gear
Default BackFiring Help
Hello all. I have a 1979 Ironhead and recently had to replace the sprocket cover gasket. While in there, with the help of IronMick, i wound up having to get the timing correct on all the gears. Now that it is back and running, it starts but backfired constantly, and when I removed the air filter from carb there was fire shooting out of the carb. (looks great...but I assume its bad)
Any help would be greatly appreciated! I am hoping to not have to start from scratch again but maybe thats the only way?
Old Nov 7, 2009 | 12:01 PM
seventyiron's Avatar
seventyiron
Are Ya certain all the marks on the cams are lined up perfectly? if so,sounds like the timing is off to me..
Old Nov 7, 2009 | 05:47 PM
IronMick's Avatar
IronMick
+1 on this. These are the two things that would be changed by removing the cam cover, the cam timing and the ignition timing.
Did you perhaps take a pic of the cams with the marks lined up?
When you replaced the timer plate how did you orient it? Did you follow a static timing procedure? Did you check the ignition timing with a timeing light?
Old Nov 8, 2009 | 11:26 AM
1979Sportster
2nd Gear
I did not take a picture (unfortunately) but am pretty sure I know what it is. You are right again! The problem I had was when I was placing the Front exhaust cam gear, I was not able to get it to the proper placement (10:00) mainly because the Tappet was stopping it from rotating far enough. I think I may have gotten it to about 8:00, so this is probably my problem? When I disassemble it again, how do I get the Tappet to move up far enough in order to get the Gear in its proper location?
Thanks again for all of your help!!
Old Nov 8, 2009 | 02:12 PM
piniongear's Avatar
piniongear
If you have to move the tappet base up to get the cam to rotate....then that is what you must do. Raise up the base!
Never install the cams with the marks mis-aligned. You are courting disaster doing that.
pg
Old Nov 8, 2009 | 06:50 PM
1979Sportster
2nd Gear
Thank you thank you! I will do so. I tried to push it up far enough to rotate the cam but wasnt able to get it to raise any further. Is there something, or some kind of trick I am missing?
(sorry for my ignorance...first time bike owner)
Old Nov 8, 2009 | 07:19 PM
piniongear's Avatar
piniongear
Here is an exploded view of the engine. You will have to remove bolt (#1) and raise the base (#3).
The base has one O ring around it (#5).
You may have to use a tool that is shown in Fig. 3-26 of the next pic.
This tool can be made at home, as I have made it before myself. Just look at the pic. The threaded bolt screws down into the tappet itself, raising the base up. Just raise it far enough to get the cam installed, then bump it back down with a soft hammer (rubber or plastic mallet).
Read carefully under Valve Tappets and Guides.
Note that it may be necessary to raise the cylinder to raise this front exhaust tappet base.
pg
Old Nov 8, 2009 | 11:43 PM
sepixlh's Avatar
sepixlh
Cam timing looks a like this, front intake had shim ...so marking don't show... but align all markings.
Spurlee
Ironhead
11
Jan 7, 2018 09:09 AM
Sossbr1
EVO
Sep 22, 2017 02:06 PM
racerx1
Jun 19, 2011 01:31 PM
dtimekw
Ironhead
Jun 30, 2008 08:25 PM
markw5
Nov 10, 2006 11:40 PM
