Ironhead A place to talk about Ironheads.
Bullet-proofing bottom end
Old Dec 20, 2009 | 09:59 AM
70Weight's Avatar
70Weight
Default Bullet-proofing bottom end
CYA sorta..no pun intended
Starting to put my winter project together,and am hoping for advise/help on building as bullet proof set of cases possible..hopefully that will last 300K.
Any tricks/techniques/brand of bearings,wheels,rods.. racers knowledge..What Ive done so far is bought a belt drive primary,blocked off speedo drive..its a 1972 set. The reason for belt primary is this is my last set of cases,and a broke belt wouldn't destroy them the way a chain would/can way I see it.Same for the speedo plug..Considering a Trock tranny door also..?
Thanks for reading..and any suggestions!!
Old Dec 31, 2009 | 08:28 AM
70Weight's Avatar
70Weight
Its done. S & S rods,Timken bearings,Trock trap door and Andrews gears.
Old Dec 31, 2009 | 01:37 PM
IronMick's Avatar
IronMick
Sorry you did not get any responses here. Could not help with this myself. Sounds like you got it done well.
Old Dec 31, 2009 | 07:09 PM
70Weight's Avatar
70Weight
Not a prob Mick, just put on the jugs...40 over pistons with Hastings rings.Cant think of a better way to spend New years Eve..but gotta take the O.L. out later..
sixty5pan
Sep 11, 2011 08:57 PM
Mr. Wizard
Jul 9, 2011 11:28 AM
EvilWayz
Ironhead
16
Apr 3, 2011 08:10 PM
BPHORSEGUY
Mar 16, 2010 11:26 AM
drake95th
Aug 3, 2006 01:47 AM
