Ironhead A place to talk about Ironheads.
Dyno charts
Old Jul 22, 2006 | 01:07 AM
SKJOLD's Avatar
SKJOLD
Default Dyno charts
Has anyone here ever dyno'd their Ironhead? If so post them here. I am curious what you all are getting as far as power and torque curves.
Old Jul 26, 2006 | 05:44 PM
74_ironhead's Avatar
74_ironhead
Default RE: Dyno charts
OK since you asked, I know it looks sad but I tuned it up the way the guy told me and I can tell that it's better than this
Old Jul 27, 2006 | 02:29 AM
SKJOLD's Avatar
SKJOLD
Is this rear wheel torque and HP? What kind of carb are you using?
Old Jul 27, 2006 | 12:30 PM
74_ironhead
yes it's rear wheel with an '03 CV carb it needed a rejet at the time but, the guy said that was pretty common for an ironhead
Old Aug 7, 2006 | 04:08 PM
Spectrexx's Avatar
Spectrexx
I've dyno'd mine a couple times, but didn't save the charts. Mine was making almost 90 HP/97 ft lbs on the best run, though. The engine has 12.5:1 compression Wiseco pistons, dual plugs, Chevy points, Accel coil, S&S Super E carb, Andrews Y cams, and heads ported, running Cycle Shack slip-ons on 1.75 inch pipes at the time. I tried drag pipes, but it ran like crap below 4000 rpm. They are really only good for top end performance. I was using a 50/50 mixture of 93 octane Sunoco gas and 100 octane low-lead AVGAS. She has almost as much pep as the XR750s I used to race. Of course, the XR only weighed about 300 lbs compared to the 425 lbs (I lightened it quite a bit) that the XLCH weighs.
Old Aug 9, 2006 | 04:09 AM
SKJOLD's Avatar
SKJOLD
Wow, is that with stock Bore and stroke?
ORIGINAL: Spectrexx
Old Aug 9, 2006 | 01:55 PM
Spectrexx's Avatar
Spectrexx
No, the stroke was stock, but it was bored .060. Not enough to really make much of a difference in power.... I just did it to remove the scratches in the cylinders. I ended up replacing them a few years later, so it was back to stock bore. I didn't notice any loss in power (seat of the pants) when I did that.
Old Aug 21, 2006 | 09:06 PM
SKJOLD's Avatar
SKJOLD
Can it be run on pump gas with that compression ratio?
ORIGINAL: Spectrexx
Old Aug 30, 2006 | 01:15 PM
Spectrexx's Avatar
Spectrexx
Not unless you retard the ignition so far that it won't run at all. I'd only run pump gas (93 octane) on CRs of less than 10.5:1, and even then you might need octane booster. In fact, I wouldn't build a street bike with a CR of more than that. My Sporty is mainly set up for racing. I don't usually run it on the street anymore since it's getting hard to get AVGAS. You might be able to find some racing fuel, though (for a lot more $$).
DK Custom
Apr 5, 2017 10:37 AM
kountry
Feb 16, 2011 12:29 PM
flip180
Apr 27, 2010 09:08 AM
RjCapp
Exhaust System Topics
Oct 28, 2006 02:09 AM
CJKCyclone
Jul 1, 2006 08:02 PM
