Ironhead A place to talk about Ironheads.
head bolts
Old Mar 6, 2010 | 12:40 PM
popstheoldman's Avatar
popstheoldman
Default head bolts
i have a 82 sportster and can't seem to get a torque wrench to it is there a trick?or do i have to pull the motor?
Old Mar 6, 2010 | 02:06 PM
IronMick's Avatar
IronMick
The trick is to cut/bend/whatever a wrench to make it fit, then consult a torque conversion table to see how the extension affects the torque value.
I have not done this myself so that is as specific as i can be. I am not going to admit publicly on this forum that i guess at the 60 ft lbs required for the head bolts, and the 30 ft lbs for the cylinder nuts. Ooops, i guess i just did that, eh.
Old Mar 6, 2010 | 06:00 PM
47Harley's Avatar
47Harley
I just tighten it down until I feel it's tight enough I'll admit it on the forum. After you tighten "torque" them down start it up and run it until it's warm then shut it down until it cools and re "torque" them down again.
Old Mar 6, 2010 | 06:50 PM
IronMick's Avatar
IronMick
Check post numbers 10 and 16 in this thread on another forum ...
http://xlforum.net/vbportal/forums/s...d.php?t=395586
Old Mar 8, 2010 | 10:04 AM
Calwoodbutcher's Avatar
Calwoodbutcher
This bad boy here will work well.
http://www.sears.com/shc/s/p_10153_1...3253000P?mv=rr
Old Mar 12, 2010 | 08:28 PM
straydog13's Avatar
straydog13
i dont think i would count on the torque being absolutely correct with using a swivel.i guess it would depend on how it was binding.i am not saying it is worse than guessing though...what i did was made sure the bolts screwed in equally well and then finger tightened them,i made a mark on the bolts,then i torque the ones i could a little at at a time....each torque turn i would stop and turn the one i coudnt get to an equal amount.---thats what i did i am not saying its the best way i am just saying that swhat i did.
ubreal
General Topics/Tech Tips
17
Sep 9, 2016 09:28 PM
felix27
Jun 22, 2016 11:34 PM
PHAT A$$
May 15, 2009 01:04 PM
wolfydude
Feb 21, 2009 12:04 AM
twilliams
Jun 20, 2007 10:16 AM
