does anyone know what the c.c.a. is for an 82 sporty as i have a H.D.batt.
part #65991-82B.nobody seems to know how many cold cranking amps. it is?not even dealer where i bought it 3yr's ago.its a maitanence free batt. i had it tested at advance auto and the readin says 13.28 volts but only 97 c.c.a.
on a fully charged batt. i've been having startin problems lately.it barely cranks the starter before the solinoid starts to chatter
I do not know the answer to this. However, every comment i have seen about HD batteries, including my own experience, is that they are the best choice. I would just get another from the dealer.
my 74XLH was always a slow crank.
I replaced mine with a Scorpian Battery.
$100.00
Model: YIX28L 12v HVT-7 HD
Cold Cranking Amps (CCA): 380 A
The only good thing I have recieved from China.
Bike turns over great now.
what gets me is the test results:13.28 volts and only 97 cold crank amps just doest sound right.it got the volts but not the amps? 3 yr.old mait free batt.
It's not uncommon for a battery to put out the proper voltage and at the same time fail the load test. It just means the battery is at the end of it's life and time to be replaced.
On the advice of wrench friends who knew more I once replaced the starter on my Ironhead when it turned out all I needed was a new battery for the above reason. That and some serious crow eating apologies from my motorcycle mentor who bench tested everything for me first...but failed to do a load test.
You did a load test. It failed. Time to get a new one.
It's not uncommon for a battery to put out the proper voltage and at the same time fail the load test. It just means the battery is at the end of it's life and time to be replaced. ...
$100.00
Bucaman
This -74 XLH has 32Ah battery, newer -79 has only 18Ah battery. CCA amps are most likely different...
