Ironhead A place to talk about Ironheads.
Carbs
Old May 17, 2010 | 10:21 PM
IronMick's Avatar
IronMick
A problem with no acc pump is that you can not always accelerate quickly with sudden throttle openings. You have to roll it on. If you have been riding with such a carb for a long time you get used to this and do not notice - until you ride with an accelerator pump carb.
Old May 18, 2010 | 04:28 AM
47Harley's Avatar
47Harley
The only problem I've seen with them is when people try to repeatedly blip the throttle at lights. If your carb is properly tuned cracking the throttle wide open while in gear is no problem because the bike rolls into acceleration anyway. The accelerator pump does come in handy on cold mornings when your in the driveway at 5a.m. trying to kick her over though.
Old May 18, 2010 | 01:25 PM
gunnut1's Avatar
gunnut1
I replaced the HD carb (with adjustable XLR main jet ) with a new S&S on my 1970 XLCH (77 CU IN ) in about 1975. This was a new S&S with no accel. pump, started great and ran a little better at low speed, couldn't touch the HD carb with the accel. pump for performance. That pump is what gives you the "seat of the pants" power.
Old May 18, 2010 | 02:57 PM
47Harley's Avatar
47Harley
It must just be a tuning issue. I have spent time tuning and tweaking and have no problems keeping up with 1200 Sporties all the way through the range with no acc pump.
Old May 21, 2010 | 04:51 PM
70Weight's Avatar
70Weight
Is that Your bike in the picture? If so it sure got burnt bad.
Looks like a challenge there.. I would recommend the Mikuni VM38..find a used one for cheap or a Shorty E..Bendex, all good carbs.
supermanotorious
Mar 25, 2018 09:36 AM
JW1200
Apr 19, 2010 08:18 PM
Wireguided
Shovelhead
Sep 2, 2008 02:06 PM
fxstcguy98
Exhaust System Topics
Aug 8, 2008 10:10 PM
dert
Feb 3, 2006 10:26 AM
