Ironhead A place to talk about Ironheads.
Weld on hardtail
Old Aug 22, 2010 | 11:04 AM
Road6Customs's Avatar
Road6Customs
if your DMV is anthing like ours, do a weld on. Its about impossible to get the paperwork done on a custom build, and you can still insure it as a Harley. Good luck!
Old Aug 22, 2010 | 01:40 PM
TwiZted Biker's Avatar
TwiZted Biker
For a 70 sporty the weld-on is the way to , easy set up and you can clean everything up pretty well cheapy HF grinder , done right it's stronger than an after market frame around $200 ? verse $700 + ? .I haven't done one in a while don't what they cost anymore , but all the above post's had very good points . Your title nor your insurance will change it's the same bike you have just added an accessory .
Plus look at the extra money to spend on bling .
There's not much difference in the frames and the add on section has to be Tweaked a bit to fit , never seen one yet that was spot on just close so yes you can fudge it around and it will work fine . I've done this to 8 sporty's & and at least a dozen big bike's over the years , go for it .
Check this link lots of info and tips just for what you want to do .
ChopperWeb.info
hubcap
Aug 18, 2019 09:13 AM
I_am_10_ninjas
May 2, 2011 06:13 PM
Johnny-5
Apr 29, 2011 12:51 AM
GONZEE
Feb 13, 2010 07:40 AM
shavorhead
Panhead
May 11, 2008 06:33 PM
