Ironhead A place to talk about Ironheads.
Sheared starter gear
Old Aug 7, 2010 | 05:13 PM
bfgoodmudder's Avatar
bfgoodmudder
Default Sheared starter gear
Got the 76 back together today, went to fire it up and nothing but that awful ratcheting that leaves an empty feeling in your gut. Pulled the starter off to find all teeth about half gone. I did find a Hitachi replacement for 70 bucks but of course I have to wait on snail mail. Problem is, what the hell is causing it? It does kickback pretty good at times but I'm not sure it means the timing is off. It runs well enough that I doubt it. With the plugs out, the sheared starter would still spin the motor but when I put'em back in, it ratchets. I don't wanna shell out another starter so....any ideas? Thanks
Old Aug 9, 2010 | 02:25 AM
bfgoodmudder
wow....nuthin huh?
Old Aug 9, 2010 | 11:45 PM
sepixlh's Avatar
sepixlh
You are right about timing, it's off if engine kicks back.. check it first. Bike runs nicely when timing is too much advanced, but starts badly.
Old Aug 10, 2010 | 02:34 AM
bfgoodmudder
I think I got the timing right now. I found TDC, then used the ohm meter to adjust the points with the small lobe so that you can open and close the circuit by pushing the cam back and forth with your finger. I'm told the small and large lobe should be within .002 of each other but I haven't checked it yet. It's still not running perfect but it's getting there. It will idle now anyway. Took it out on the highway and wound her up. Seems like there should be a little more. Slight miss at high rpm too. I guess I'll check the valves and have another look at the carb. Oh, I was also told to check the counter weights behind the points. Plenty to tinker with yet. It felt good to finally get out and ride a bit though.
Old Aug 10, 2010 | 05:16 AM
IronMick's Avatar
IronMick
Review this YouTube video for timing ...
http://www.youtube.com/watch?v=mKVh4pbyh2A
Terry McKenney
Oct 24, 2015 07:15 PM
LtlNicky
Feb 7, 2014 12:44 AM
Go Shovelhead Go
Feb 15, 2010 10:21 AM
maddghost
Aug 13, 2009 03:19 PM
bdejong11129
May 8, 2008 11:22 AM
