Folks,
My old tailight was toast. I managed to get a new tailight my neighbor took off of his 90s Dyna. Here is my question. The old tailight had two wires. The one off of the Dyna has three. Can I use this sucker and WTH is the third wire for? Oh, if I can use it which two of the wires do I connect to my two leads? Thanks.
Use an ohm meter connected to the new light to determine which one of the three wires is the ground. Connect this to the fender.
Use a 12v battery, or better yet, connect the brake light wire on your bike directly to one of the new wires and then to the other wire on the Dyna T/L. Step on the brake pedal each time. The brightest connection is the brake lead of course. The remaining gets connected to your taillight wire.............pg
I don't know what is up with the aftermarket replacements. They are cheap copies that don't hold up long. Guess maybe I ride in the rain too much. They just rot out the socket. I put silicone grease around the connections and get a little more life. Crappy screw posts also. I think PG has the right info on the 3rd wire.
