Break light modulator question
Old Mar 24, 2012 | 02:11 AM
HOMBRE2011's Avatar
HOMBRE2011
6th Gear
Post Signal Dynamics Back Off XP question
I'm asking anyone who has installed the Signal Dynamics Back Off XP model on thier bikes which wire to connect it to. I've planned on hooking into the wire harness going into the rear fender but wanted to know which color wire is the right one. Can anyone tell me what color wire is the "brake light" wire? Sorry, I don't have the service manual to look this up myself, and the Harley dealers are pretty stingy with information.
Thanks in advance for the help.
Old Mar 24, 2012 | 06:42 AM
Lowcountry Joe's Avatar
Lowcountry Joe
That XP version, on the website, indicates it is for bikes with dual brake lights. Don't know what you mean by "hooking into the whip".
http://www.customdynamics.com/pdf/wi...structions.pdf
Can't help you on which wire is the brake light wire under your seat. I only have a manual for my bike.
Old Mar 24, 2012 | 07:08 AM
HOMBRE2011's Avatar
HOMBRE2011
6th Gear
Question
Thank you Lowcountry Joe but those same type of instructions came with the module. I did not buy the "wig wag" module that you posted the link too. The "whip" I'm refering to is the group of wires that run under the rear fender to the brake and signal lights. They connect to the main harness near the battery.
My question; has anyone hooked up this module and if so what colored wire is the brake wire that I have to splice into?
Old Mar 24, 2012 | 09:37 AM
Retrop's Avatar
Retrop
In a pinch I would try this: Pull the plastic tail light off and look at what colored wire is going into the bulb assembly. That should match up with the same wire in your "whip" shouldn't it?
Hell, I don't know.
Old Mar 24, 2012 | 02:08 PM
HOMBRE2011's Avatar
HOMBRE2011
6th Gear
Thanks Retrop
BUMP
Old Apr 25, 2012 | 02:40 AM
HOMBRE2011's Avatar
HOMBRE2011
6th Gear
Talking Help
BUMP / RE-SUBMIT / STILL NEED ANSWER
Old Apr 25, 2012 | 05:16 AM
Beav's Avatar
Beav
Talking
Best $60 you'll spend on your bike.... don't know if "whip" is in there though.
Many here to help, IF you'll help yourself.
Beav
Old Apr 25, 2012 | 10:55 AM
3/4 life crisis's Avatar
3/4 life crisis
Red w/ orange at the tail light.
Old Apr 25, 2012 | 12:31 PM
HOMBRE2011's Avatar
HOMBRE2011
6th Gear
Beav-I agree with you completly I need the service manual, but as you stated the wire diagram may not be in it. I went to a dealership and they wouldn't break the plastic for me to even look inside one. Can't say I blame them but I would have bought it if it had what I needed. Chicken or the egg proverb. I am hoping that at least someone here has either installed one or has a sevice manual to look it up.
3/4 life crisis-simple and to the point, I thank you.
DaddyKnuck
May 31, 2017 09:57 PM
VTwinfelipe
Electrical/Lighting/Alarm
Mar 21, 2017 04:30 PM
07hdsporty
Apr 15, 2015 04:26 PM
Finmad
Aug 7, 2014 07:41 AM
emperor wurm
May 21, 2012 03:58 PM
