Trying to get her started
I have a Mikuni and bought it in 1973. It is the best! I currently run a Bendix and it is second best.
So why did I not mention the Mikuni before?
Because I do not think it will work with a magneto.
Too little room above the mag.
But if you measure what space you have and find that the Mikuni will fit, your search is over. Buy that carb!
Here is a pic of my 1971 XLCH with the Mikuni.
I have the timing cover distributor so space is not an issue. With a mag I believe it will be an issue. So be careful with the carb purchase.
pg
Decided to try running it down the road now. Which I have about a two hundred foot gravel driveway down hill. Being the first time I have ridden any kind of serious bike I was a little worried. But I made it, both feet dragging in the gravel until I got to the road. Now I live on a major highway where the speed limit is 55 so I was also worried about cars topping the hill. I revved the engine, started to let out on the clutch, and started moving but the clutch was pulling harder than I thought. I ended up going straight across the road in my uncle's front yard, I tried to ragain my composure and start to turn back to the road. As I was turning around in his yard the bike coughed and died. That was it. I tried getting it started with no results. I finally walked back across the road got my truck and trailer, loaded it up, and parked it back in the carport. Need less to say it was fun while it lasted but I am going to need some practice to get used to the clutch. And I have talked to a local shop that works on Harleys and they told me to get a S&S carb because they have a shelf full of the Keihin/Bendix carbs. Hopefully that will fix all my starting and running problems.
Now on to the subject of the mag. The guys that have seen my bike after I bought it say they knew the guy that built the bike. They have told me they saw the bike running but some things have changed. It originaly had a girder frontend but that has been changed. So the mag could have been changed but why would someone change to an older style cover and mag if they had points and a newer cover already?
I did go back through your posts and did find some pics. You have a bendix...they are great. the pics I saw were old (last year) and things were looking a little rough. I'll assume you have gotten the carb cleaned up a bit...the pic was fuzzy so, I could not tell the age of the carb(later Bendix carbs have an adjustable main jet--early ones are fixed). However, if you've had the carb apart and there are no breaks or cracks or any other damage then keep it and just learn to tune it and work with it. It is probably set up already for the bike and just a matter of tuning the bike properly...buy a new carb and then you will have issues with a bike that has tuning issues and a carb that needs to be tuned to match the bike...a no-win situation that will drive you crazy!!
"why would someone change"--everyone changes something on a bike. Sometimes just add some bling, sometimes cut, chop, and rebuild...it's a bike thing. You make it your own...sometimes your own changes again and again.
The issue with restarting after I have run it for a few minutes. I am not opening the throttle when I try it. I may take less than a 1/4 twist on the throttle after quite a few kicks and only get a kick back. Can anyone tell me some of their tricks to give me something to go by?
I would encourage you to solve the tuning issues before you spend money on a new carb. Then...if you want a new carb...for whatever reason...buy one.
I would check for intake leaks. It sounds like you have already had the carb off.
Check your compression (easy way to check lifter adjustment)
carb adjustment (is your main adjustable or not)
When you had the carb apart did you clean it well? replace the o-rings (if the o-ring on the main jet isn't tight fuel can be drawn past the jet instead of through it creating a rich condition, fouling plugs and result in poor running or stall), clean all the fuel passages, and accel pump, what is your idle speed?
and your timing...Pinion made a good point earlier, but I'd still put a light to it to get a value at which it runs best.
I have not put a timing light on the bike since I cannot get it to idle. But as I stated earlier. Will the mag not being able to retard the timing really effect the tuning? And if this is the case what would you recommend to resolve this?
I have run the Bendix for the past 7 years simply because I like the two piece handlebars and enclosed throttle cable.
No other reason.
I bought the Mikuni in 1973 as I said and I ran it until 2004 without a single problem.
Jeez......that's 31 years!
I dunno, I suppose it made a believer out of me, and you will see me waving the Mikuni flag anywhere I am caught talking about carbs for a Sportster.
pg
The only tuning adjustments you have are idle mix and idle speed. The main jet is fixed and you may want extra jets (one up and one down) if you travel much...I've changed mine on the side of the road a few times through the mountains in BC.....but that is an issue for much later.
...but, there is still intake leaks to check for anytime the carb comes off
"I may take less than a 1/4 twist on the throttle after quite a few kicks and only get a kick back"--try 1/2 twist, if that doesn't work check plugs (wet? sooty?), try new plugs and retry.
yes
If you don't believe the mag is seated properly than lift it and bump it one tooth in the direction needed to achieve the ability to properly set timing.
BUT...if you ONLY mean because someone has made a fixed mag out of an adjustable one...then no(I'll find those pics again and look at this). The earlier mags were fixed...as is mine...and it works just fine.
I'm really starting to think intake leak...based on what I'm reading. spray WD40 all around the intake seals and back of the carb...a quick, easy check...
