Ironhead A place to talk about Ironheads.
oil pressure issue?
Old Apr 27, 2011 | 05:08 PM
lewzab's Avatar
lewzab
Default oil pressure issue?
hi ya
finally found the time to fire up the 79 xlch chop after the rebuild and have fitted an after market oil filter and used clear reinforced oil line from the oil pump return to the filter then braided line from filter to oil tank so i could see that i have oil circulating to the filter but i only seem to get pulses of oil with a lot of air i have bled the pump via the oil pressure switch but that has made no difference is that normal or should it be a constant stream of oil ,i also have slight oil leaks that seem to coming from between the heads and barrels on both cylinders it runs down the fins onto the exhaust headers and burns off i have used new gaskets and have torqued the heads to the spec in the manual and have checked again to make absolutly sure yet i still have the problem,could really do with a bit of help here im so close to getting back on the road with her but dont want to run the risk of destroying a total rebuild thats taken me 2 years in 5 mins, cheerz guys
Old Apr 27, 2011 | 10:43 PM
IronMick's Avatar
IronMick
For oil leaks i clean it all up well then stuff paper towels into sustected places; then let it sit overnight or take it for a ride or both. Sometimes i takes 3 or 4 rounds to isolate the leak.
It would be rare, but certainly not impossible, to get oil thru a head gasket leak. Usuall you get a loud whistle souns as air squeeks out. However there are two oil holes; if the gasket seal is bad between the hole and the outer edge of the gasket, but good to the inner edge, you will get oil.
Stuff paper towels between the head and the cylinder fins. Clean it thoroughly first.
I have never used clear oil line so i do not know hwat it usually looks like in there.
Buns79
Feb 28, 2016 07:57 AM
bbmfic
Nov 7, 2014 07:54 PM
bbull55
Custom Models
Aug 15, 2010 10:41 PM
64 ionhead
Jun 18, 2010 08:09 AM
LiLCricket
Sep 23, 2007 02:23 PM
