Ironhead A place to talk about Ironheads.
Torque Specs
Old Apr 30, 2011 | 12:07 AM
Ironhead Ed's Avatar
Ironhead Ed
Question Torque Specs
I am having a hard time trying to find a couple of tourque specs for the engine assembly. It's an 83 Sporty Ironhead
Also I want to know what section I need to look in to find the specs in the service manual.
Here is a pic of two of the torques I need. I would call them flywheel nut and clutch hub nut, just a guess though.
ALSO, I can't find the torque specs for all of the bolts that hold the two engine halves together.
ANY HELP WOULD BE GREATLY APPRECIATED
Old Apr 30, 2011 | 07:40 AM
IronMick's Avatar
IronMick
Factory service manual 99484-85 page 3-2.
Old Apr 30, 2011 | 08:33 PM
piniongear's Avatar
piniongear
150 ft lbs on each nut. Then be sure to bend the tab of the clutch hub washer down against the flat of the nut.
pg
Old Apr 30, 2011 | 08:49 PM
Ironhead Ed
sorry guys I didnt think anyone reponded yet because I did not put a notifaction on the thread for me. You guys are great! Any luck at finding the engine halves torque specs?
Old Apr 30, 2011 | 10:37 PM
piniongear's Avatar
piniongear
Tighten the crank case bolts in a cross pattern to 10 ft lbs each.
Then using the same cross pattern, do a final torque of 15 to 19 ft lbs for each bolt.
You will not find this in the service manual.
(Figures taken from the 2003 Dyna Factory Service Manual)
Here is a list of torque values given in the Dyna Factory Manual for different size (and different strength) bolts.
Copy it and pin it up somewhere.......................
pg
1993evo
Sep 26, 2015 08:32 PM
hillbillyphil
Nov 13, 2013 02:41 PM
DDDDylan
Ironhead
Oct 3, 2012 05:57 PM
Gliden
Apr 13, 2010 02:14 PM
78flh
Feb 11, 2007 12:43 AM
