Ironhead A place to talk about Ironheads.
I think this will work
Old Jun 25, 2011 | 05:22 PM
GREATLAKESAUTO's Avatar
GREATLAKESAUTO
Stage I
Default I think this will work
I HAVE A 1966 XLCH THAT I GOT IN A BOX ABOUT 10 YEARS AGO AND AFTER 300 HOUR AND LOTS OF MONEY I THINK IT WILL RUN. BUT I HAVE A P I PUT A AUTOMATIC ADVANCE AFTER MARKET DISTRIBUTOR IN IT BUT I AM NOT 100% THAT I HAVE IT TIMED RIGHT OR AM I JUST NOT KICKING IT HARD ENOUGH TO START IT PS. THIS IS A 900 KICK ONLY 40 OVER ANDREWS CAMS AND EVERY THING IN SIDE THE MOTOR IS NEW ONE OF MY FRIEND WAS HELPING ME BUT PASSED ON SO I AM ON MY OWN AND HELP WOULD BE NICE THANKS
Old Jun 25, 2011 | 06:55 PM
IronMick's Avatar
IronMick
Sorry i am unable to help with this one. Someone should be along who can help. But may i say Congratulations! on your 1966. Many believe the 60s IronHeads are prime.
Please if possible turn off the CapsLock while you type. On internet forums it is considered to be the same as shouting while talking.
Old Jun 26, 2011 | 10:06 AM
scottfisher's Avatar
scottfisher
The timing is set up like any other points system.
look for the timing mark in the window, static time it with a light or meter.
You may find the following threads helpfull:
http://xlforum.net/vbportal/forums/s...d.php?t=317401
http://xlforum.net/vbportal/forums/s...d.php?t=231711
http://xlforum.net/vbportal/forums/s...ad.php?t=39764
You have spark I assume? and obvious fuel flow?
are you getting kick back or popping? smoke?
Old Jun 27, 2011 | 02:53 AM
81ironhead's Avatar
81ironhead
6th Gear
Congrates on the bike and good luck
Old Jun 27, 2011 | 05:50 PM
piniongear's Avatar
piniongear
Knowing a few details is going to help diagnose the problem.
It could be a number of things, or a combination of several.
What kind of carb do you have on it?
If it happens to be a Tillotson then that is going to be a big problem.
If the carb is stamped Bendix or Zenith (same carb) then that is a good thing.
If you cannot determine what brand carb then just post a pic of it here.
With regards to the ignition system:
Are you certain you have the points gap set at .020 exactly?
Before you do anything else, remove both spark plugs and install the plug wires on each.
While grounding the plugs against the head kick the engine over and observe the spark.
If you are getting spark then take one plug wire off and stick a round phillipps screwdriver down in the boot.
Hold the steel shaft of the screwdriver an eighth inch away from the cylinder head and observe the spark.
It should be BLUE in color and should ZAP! when it goes off. Do the same with the other wire.
If the spark is weak and fuzzy with no zap then you have a problem with the ignition. A good blue spark means the distributor is OK and it is time to check the carb and the ignition system.
Lastly, you do know how to time the ignition....... or not?
pg
Tj Klatt
General Topics/Tech Tips
Sep 10, 2016 11:23 PM
sic-puppy
Jul 26, 2013 01:37 AM
sailnjay
"The Florida Crew"
Feb 5, 2012 09:01 AM
ledsledz
Sep 1, 2009 05:54 PM
xrayv65
Exhaust System Topics
Aug 20, 2009 08:28 AM
