Ironhead A place to talk about Ironheads.
weird steering issue
Old Apr 4, 2012 | 11:57 PM
Joshua Thompson's Avatar
Joshua Thompson
3rd Gear
Question weird steering issue
I'm looking at getting an 81 sportster and when I went for a test ride I could push on the handle bars and if felt like I was pushing the entire front assy forward like the goose neck area was out of wack. Is there a simple tightening I can to do tighten it up so it's not so soft and stiffen it up to make it feel better?
Old Apr 5, 2012 | 06:23 AM
IronMick's Avatar
IronMick
There are rubber bushings, part number 56158-73, between the risers and the frame. These become worn and the handle bar has a lot of flex. You can replace them. Replacements are readily available from an indie motorcycle shop, J&P Cycle, etc. They come in different materials so you can get solid or simply firm ones. You will need to do some research to determine what to get. Someone else here may know more.
Old Apr 10, 2012 | 07:25 AM
Bama91's Avatar
Bama91
What IronMick said plus check for a cracked riser. I had a riser crack on the bottom and it had some wobble to it. The OEM risers were die cast aluminum so over tightening could bust them.
Old Apr 10, 2012 | 08:07 AM
Joshua Thompson
3rd Gear
I should have my bushing replacement kit in today from my local bike shop, I'll double check the riser but I think it will be the bushings well at least I pray it is.
wyotana
Jun 19, 2019 05:52 PM
TWNomad
Jul 23, 2013 10:21 PM
big papa AZ
Apr 14, 2013 04:20 PM
09fatbob
Sep 25, 2008 05:12 AM
98fxd
Jun 27, 2005 02:08 AM
