Ironhead A place to talk about Ironheads.
Choke Question
Old May 24, 2012 | 08:23 PM
scottfisher's Avatar
scottfisher
Good Thread:
http://xlforum.net/vbportal/forums/s...ht=bendix+carb
Old May 24, 2012 | 11:00 PM
Can't Wait 2 Ride's Avatar
Can't Wait 2 Ride
Originally Posted by scottfisher
Very informative thread - thanks. I'm getting a good stream of fuel into the carb when I crack the throttle although the thread suggested taking out the in-line filter and checking the petcock first. Are these good starting points before I venture into removing the carb for a rebuild?
Old May 25, 2012 | 08:44 AM
piniongear's Avatar
piniongear
Here is how I hooked up the choke on my Bendix (Zenith).
I turned a brass ****, then drilled a hole sized to create a tight push fit, shoving a spoke nipple into the brass ****.
I cut off a length of spoke to make the rod and threaded the end into the nipple.
The scary part is drilling the hole into the carb body then tapping that hole with #8-32 threads for the allen head screw to fit in.
There is plenty of body there to accept a drill bit for tapping the hole.
pg
Old May 26, 2012 | 09:01 AM
scottfisher
If you feel your carb appears to be functioning properly. I would be inclinded to look into other areas for the tuning issue before tearing into the carb. I'm makiing the asumption that the bike has been running well and this issue is a recent (perhaps gradual) development. If the bike has been sitting or has unknown history (ie you just got it and haven't been riding it) then I would look at each component fully (ie--yes, I would tear apart the carb and give it a good cleaning) to ensure each component is working correctly and to it's full potental.
does it idle well?
start easily?
fresh plugs?
check push rods
timing
fresh gas
plug wires in good shape, contact points are clean (at each end of the wires)
ignition components are all intact and appear to be functioning
if everything checks out ok, then go back and look closer at each component...start with the carb if you want. try making adjustment to the mixture; try and drive it--no change? better/ worse. set it where it works best.
then open it and see if the o-ring on the jet has deteriorated, float level...etc
only focus on one thing at a time. If you make multiple changes and it gets worse or better or stays the same you won't know if your heading in the right direction and one change might fix it but the others make it worse. You will end up chasing your tail.
Old May 26, 2012 | 10:13 AM
Can't Wait 2 Ride
Scottfisher - That's sound advise and was the route that I was planning on taking. I recently purchased the bike and from what I was told it has sat for awhile (3-4 years) and ridden only about 10 miles during that time.
One thing I did notice this morning was that the petcock and carb were both very damp and a small amount of fuel had accumulated on the top of the motor below the carb. I small a very slight leak from the bottom of the bowl. I checked the petcock and it was in the off position (lever horizontal). I removed the fuel line from the carb and placed it in a clean mason jar. I thinking that if the petcock is not working in the off position, then it may not be functioning properly in the on position either. I don't have my parts catalog yet so does someone have the part number and a good source to purchase a new petcock. I might as well start with the obvious.
Thanks to everyone for all the helpful info and happy Memorial Day.
Old May 26, 2012 | 10:42 AM
piniongear's Avatar
piniongear
+1 on everything Scott suggested.
What I have to ask is what are your issues?
(1) Is the bike running and starting well?
(2) Do you have some specific problem?
If the answer is yes to the first, and no to the second question....then leave it alone.
Working on it is going to kjust screw a good running bike.
pg
Old May 26, 2012 | 10:52 AM
scottfisher
there is a small 'overflow' hole on the back of the carb. It is prob not leaking bu rather overflowing.
That being said.
It seems pulling the carb and giving it a good cleaning may be a good place to start.
The symtoms you indicate are a sign of a rich running motor (among other things) and a leaking carb can cause this.
You may find the float needs adjustment, or/and the needle valve is worn/not seated properly causing the bowl to over fill.
I get parts from a local indie, local dealer, J&P, ebay, swapmeets, barnett, etc etc.
I try and get the best quality parts rather than the cheapest. J&P, for example, has brand name and no-name parts available. It is worth the extra cost and ride, rather than save now and push later.
Old Jun 3, 2012 | 08:00 PM
ActsCh7's Avatar
ActsCh7
You didn't specify if the bike ran long enough to warm up. Compensating for a cold engine with throttle could cause it to backfire (through the carb or pipes?) and run rough. But my guess is that the carb needs a thorough cleaning to remove gum and possibly a rebuild if parts are worn or "O" rings or gaskets are dried out. A rebuild kit is cheap enough and comes (usually) with a nicely detailed instruction set. The choke should be replaced, you'll need it. You can rig something yourself but better to find the correct parts. Fasten it to the left side. It makes it easy to adjust while riding by letting you keep the throttle working until fully warm.
Old Jun 4, 2012 | 08:46 AM
Ironhead Dave's Avatar
Ironhead Dave
As for your leak...Check the drain plug on the bowl. People feel the need to overtighten them and it cracks the bowl. It is real easy to do. You can patch it with gas tank repair and it will hold for a couple years. I just pick up a couple bowls at a swap meet to keep on hand.
Old Jun 4, 2012 | 09:58 AM
Can't Wait 2 Ride
I'll check into that too. I've just pulled the carb and a rebuild kit is on the way. Thanks.
Fblo1690
EVO
Sep 21, 2017 03:09 PM
Speleo
Exhaust System Topics
Apr 28, 2013 10:54 AM
cobrahd1999
Carburetor Related
Oct 11, 2011 07:47 AM
Deuced512
Aug 1, 2007 03:02 PM
Lord Tarl
Jun 1, 2007 10:00 AM
