Ironhead A place to talk about Ironheads.
Small explosion in carb
Old Feb 26, 2014 | 07:07 PM
Harbri's Avatar
Harbri
Default Small explosion in carb
At times i have a small pop or explosion when i go to give it gas ,that is waiting for a red lite at the signals.I have a 1975 sportster with a mikini carb,it has been doing this for a while,just a small pop when i give it gas to go. Any ideas? Timing advanced ,retarded ?
Thanks.
Old Feb 26, 2014 | 07:10 PM
johnjzjz's Avatar
johnjzjz
you have a vacuum leak - take the manifold off and re seal all of it before doing anything else -- jz
Old Feb 26, 2014 | 07:14 PM
TwiZted Biker's Avatar
TwiZted Biker
Big time intake leak , do what John suggested redo the intake manifold seals .
Old Feb 26, 2014 | 07:34 PM
Harbri's Avatar
Harbri
Ok Thanks guys,i will check this tomorrow night.There is a y there that attaches to both cylinders then to the carb,i have all ways had a hard time to attach this piece good ,it all ways keeps moving ,you need 3 hands.i think there are 2 o rings there and i used gasket paper to go around,then the steel clamps.Any segustions?
Harbri
Old Feb 26, 2014 | 08:13 PM
johnjzjz's Avatar
johnjzjz
use a majic marker when taking it off - like a timing mark - after you attach the manifold to the stay ( the upright between the center case bolt and the bottom bolt on the manifold ) if it was in the right place you want to put it back in the same spot - than >
once its set in place with the O rings on the Y and use electrical tape to keep it in place - rap the tape around and over the top of the rubber o rings ( twice around ) than put the clamps on and leave the tape in place -- johnjzjz
Old Feb 26, 2014 | 08:35 PM
ROTTEN ROB's Avatar
ROTTEN ROB
Make sure you don't over torgue the clamps,this will cause it to leak more.And make sure the carb has a support bracket......
Old Feb 26, 2014 | 09:23 PM
IronMick's Avatar
IronMick
Is it a Mikuni VM38-9? What air cleaner are you using? What adapter between the manifold and carb? Pics of the setup would help.
It is very important to have a support bracket - usually running from the back of the air cleaner to a lifter block bolt.
A good way to check for intake leaks is, with the engine at idle, to aim a propane [from a not-lit propane torch] at the connections between the cylinder heads and the manifold, the manifold and the carb, and the carb and the air cleaner. Any change in the RPM [usually drops] indivates a leak.
Old Feb 28, 2014 | 07:35 AM
Harbri's Avatar
Harbri
Yes i am running a VM 38 carb.I am supporting it with aircraft safty wire. Where would you put the support braket?Using a round K&M filter,a lot llighter then the big oval harley one.
Thanks for all your info.
Harbri
Old Feb 28, 2014 | 12:30 PM
TwiZted Biker
Skip the propane torch and use a can of Brake Clean with the little tube , never did understand why some people wanted to spray a combustible fuel air mixture around a running engine with a gas tank above it and yes I've seen it go bad before .
Old Feb 28, 2014 | 03:38 PM
IronMick's Avatar
IronMick
Part number 29207-87T is a HD part made for IronHeads [despite the -87 on the part number]. It will work for many A/Cs, usually requires a little bending. Most guys make their own from a piece of 1/8" flat steel stock ...
http://www.jpcycles.com/search/searc...012733&Ntk=All
One end bolts to the front intake lifter bolt, the other to the back of the A/C. Most A/Cs have a hole for this; if not then you just make one.
Big Panda
EVO
36
Jun 16, 2017 08:06 PM
busterman2
EVO
Mar 22, 2013 04:08 PM
Duckslayer12
Jul 17, 2012 10:26 PM
1 Beat Up HOG
Dec 6, 2007 07:59 PM
rivercityslim
EVO
Nov 7, 2007 10:51 AM
