Knuckle Head A place to talk about Knuckle Head motors.
Leaking 51 pan TRANNY
Old May 5, 2011 | 09:41 PM
Slider 51 Pan's Avatar
Slider 51 Pan
3rd Gear
Unhappy Leaking 51 pan TRANNY
My tranny leaks from the 4 tranny plate mounting suds(underneath). I tried fixing this once before. Seemed ok & reinstalled. Then it leaked again with a vengence. How is this fixed? Special thread sealer, oversized studs (mine seemed fine), replace entire case, give in & replace with a completely new tranny? Leak is excessive so I can't ignor. How was this normally dealt with?
Old May 15, 2011 | 06:24 PM
sqdealgeorge's Avatar
sqdealgeorge
Default leaky studs
Can you move the studs back and forth (Trany on bench ) ? Do the case bolts look orig (no heli-coils ) ? Any repairs with lock-tite etc has to be done with a dry case
Old May 15, 2011 | 11:02 PM
j1mmy's Avatar
j1mmy
are you sure the oil isn't just pooling there,its the lowest part..i dont think the 4 studs go all the way thru to leak..if they do,there is probally damage somewhere,using thread sealant might help.. maybe a rubber Oring at each bolt
Old May 18, 2011 | 10:30 AM
TwiZted Biker's Avatar
TwiZted Biker
I'v run into that one a few times , has to dry and very clean and use Loctite 290 green or the 271 if the stud is a loose fit in the case let it sit 24 hrs to cure fully . If you have to do a thread repair on that use one piece threadserts not a heli coil those always seep oil .
If you have that much leakage are you sure the drive gear bushing isn't the problem or the seal isn't a good fit and leaking around that area ?
hallfleming
May 22, 2015 10:33 PM
Born2cure
Oct 2, 2012 12:48 PM
EagleRoar4
Sep 24, 2010 08:15 PM
becker213
Jul 9, 2007 08:51 AM
s2airflow
Mar 28, 2006 10:55 PM
