tranny leak problem
Old Sep 30, 2012 | 12:38 PM
Born2cure's Avatar
Born2cure
Default tranny leak problem
I put in 75/90 gear oil in tranny, think I messed up. I have an oil leak just the tranny for now. seems like it is comeing from the pan. I changed the o-ring just hoping but still bad. would a bad oil pan gasket cause the tranny to leak. should i drop the pan and change the gasket. or could there be another cause. wondering if the 70/90 could have caused to much pressure and blew out a seal or gasket. or crap i doun't know.
thanks guys
Old Sep 30, 2012 | 12:49 PM
2black1s's Avatar
2black1s
You sure it's not simply residual oil laying on the frame crossmember?
On my bike it's hard to drain the tranny oil without flooding the crossmember so I shove rags between the crossmember and the pan to prevent this.
Old Sep 30, 2012 | 01:00 PM
Born2cure's Avatar
Born2cure
unfortunately its a stream draining down the floor. not just a few drops deffinetly something that is not good. thanks 2black would have made my day
Old Sep 30, 2012 | 01:01 PM
SpiderPig's Avatar
SpiderPig
I highly doubt the oil had anything to do with your leak. Might want to spray the area with some Brakleen and see if it stops.
Old Sep 30, 2012 | 01:18 PM
2black1s's Avatar
2black1s
I can't imagine what could be causing a stream of oil to be leaking from doing a simple oil change. Wish I could be more help but I haven't got a clue.
Old Sep 30, 2012 | 02:31 PM
dansflhti's Avatar
dansflhti
Did you try retorqing the tranny bolts?
Old Sep 30, 2012 | 03:55 PM
1flhtk4me's Avatar
1flhtk4me
I agree that just changing the oil is not going to blow out a seal or gasket.
Either the o-ring is leaking or residual oil is dripping off the frame.
Also check the crossover pipe hanger bolts behind the oil pan.
Old Sep 30, 2012 | 07:02 PM
ShadowMonster's Avatar
ShadowMonster
Just throwing this out but is it coming from the shifter shaft seal... I changed up my tranny fluid to syn and sure enough the shifter shaft seal started to leak
Old Sep 30, 2012 | 07:21 PM
flhrbill's Avatar
flhrbill
Check the two Allen bolts at the exhaust bracket. They will loosen up.
Old Sep 30, 2012 | 07:42 PM
checkers's Avatar
checkers
Do the FL's have a dummy drain plug in lower case that is mistakenly removed to drain trans, in leu of the correct drain plug?
