M8 Detonation
Old Apr 4, 2017 | 09:18 PM
dykas's Avatar
dykas
3rd Gear
Default M8 Detonation
Has anybody had problems with their 2017 touring M8 regarding detonation (pinging)? Mine sounds like its full of coins when it get up to temperature........
Old Apr 4, 2017 | 10:18 PM
TriGeezer's Avatar
TriGeezer
Are you using the recommended Octane a dealer quality fuel. Did you change the tune? If yes to either, that might be it.
Otherwise, assuming it's still in warranty, take it to the dealer.
Old Apr 4, 2017 | 11:52 PM
FLTRI17's Avatar
FLTRI17
Been doing this since day one?
Old Apr 5, 2017 | 12:10 AM
M8Deeve's Avatar
M8Deeve
No detonation, just a lot of clatter from the top end. tickatackatickatacka sound while idling. If I had to guess its valves clacking.
Old Apr 5, 2017 | 03:14 AM
UltraSteveUSAF's Avatar
UltraSteveUSAF
I have a noise but I relate it more to dieseling. I only hear the noise when I'm rolling on the throttle. Yes I'm above 2500 RPM's, both bikes are stock. I took it to the dealer and I to was calling it detonation. He put it on the computer and didn't see anything. He did hear it but at his young age he's probably never heard dieseling like we did as kids when Unleaded first hit the streets. He's going to look into it and see if there's anything we can do.
Old Apr 5, 2017 | 04:46 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Dieseling is when you turn the ignition off, and the engine continues to run...
If you are hearing pinging, it is detonation.
Old Apr 5, 2017 | 05:57 AM
lp's Avatar
lp
I've heard it a few times while using 93 octane but I'm not worried.
Old Apr 5, 2017 | 06:23 AM
dykas's Avatar
dykas
3rd Gear
Im in Australia and our octane rating system is different than the US, but I'm using the top number here (98). I also have a breakout CVO 2014 Stage 3 which has no detonation issues with the same fuel.
I see there is an updated calibration now (723SHQ211) that has an addition field called Spark advance / Head temp! This is exactly the problem......as my M8 Stage 3 gets hot, it starts to ping its head off! Harley have obviously recognised this by adding this feature into the new calibration. It should retard the ignition 4 deg when the head temp get to 200+.
I think it has been getting worse, and I'm afraid that there is glowing damage in there. I don't know why there wasn't a dealer recall!
Anyway, Ill give it a go and let you know.
Old Apr 5, 2017 | 10:23 AM
Max Headflow's Avatar
Max Headflow
Stop filing the tank from the green pump nozzle?
(sorry,, couldn't resist)
I think mine pings ever so slightly on a hard roll-on but I haven't gotten around to logging data to see. I get a lot of valve train rattle at idle when hot. Not quite as bad as my 02 RK with H290 cam but it's noticeable. Gonna try low leakdown lifters from WFO larry when I get a chance..
Old Apr 5, 2017 | 11:09 AM
FLTRI17's Avatar
FLTRI17
I believe there is a bit of sorting left in the knock system. It's new because it is a traditional speaker-type sensor that physically bolts to the engine.
In the past the system used an ion (software) system to calculate combustion quality.
We had issues with that system due to the original modeling being too far off when modding the engine.
Now we have a hardware system (similar to most cars, etc today) that measures vibration to determine combustion quality.
This system would not work on the earlier (pre-'17) engines due to the innate vibration from the engine. Now that the engine is counterbalanced in addition to rubber mounted, the MOCO feels the new anti-knock system will work better than the ion system as performance mods come on.
Time will tell how this system sorts out,
Bob
