Ethanol
Old Apr 24, 2017 | 02:09 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Old Apr 24, 2017 | 02:46 PM
mjwebb's Avatar
mjwebb
Originally Posted by OldEnuf2NoBtr
wonder if we can get 87 octane Ethanol Free gas somewhere!...LOL
Old Apr 24, 2017 | 06:45 PM
blacktop37's Avatar
blacktop37
As the original poster I apologize I never make my words clear enough and I need to work on it. I I did not want to start a debate on whether ethanol is good or not . I know everyone is sick of those.My question was the Harley Davidson manual acts like it's the only gas you can run and it will do well with it. I already know I don't want to use ethanol but I don't want to do something if the machine is designed for ethanol only I was seeking opinions as if that would be the case and that regular premium would harm it. My feeling is that it's lawyer gobbledygook but with all the engineering that's going on maybe it does take ethanol to make it work its best
Old Apr 24, 2017 | 07:44 PM
xnysgt's Avatar
xnysgt
Hahaha, nobody ever intends to start anything. You could simply post "I just bought a new Harley Davidson ABC motorcycle and amidst the well wishes and congratulatory posts it would devolve to a smattering of posts about which model is better and why. Welcome to the it's-only-my-opinion forum.
Old Apr 24, 2017 | 08:03 PM
smitty901's Avatar
smitty901
Companies like HD have to play ball with the EPA and tree huggers if not they suffer even more . So yes the way HD words it is to appease the EPA.
I do not have an issue with 10% blend, but common sense tells you it is not the best option.
Old Apr 25, 2017 | 09:18 PM
31scout's Avatar
31scout
The 10% ethanol gas will work in your bike but that stuff is horrible in small engines especially when it sits for any length of time.
When I was able to run pure gas in my '04 EG Classic, I have gotten up to 50 MPG on the highway. With the ethanol gas, the maximum I get is 44 MPG and that's on a good day. I have a couple other bikes I ride and the results are the same, I get better gas mileage with the pure gas, sometimes more than 10% better.
Old Apr 25, 2017 | 09:37 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Harley engineered your bike to work with ethanol by adding the proper lines and corrosion protection. The oxygen sensors will handle gasoline and up to 10% alcohol. The BTU in straight gasoline is higher, so at WOT, your bike will generate more total HP. Also, stands to reason, with ethanol, it has about 3% less BTU in it than pure gas. So your mileage will be down slightly since it takes more to do the same work. My bike car very 8-10 mpg depending on how and where I drive it. I personally do not think you will notice 3% real world.
I have no choice but ethanol and I know from all these years experience, it hurts nothing. If mid-grade or premium regular gas is convenient, go for it. It will run just fine.
Old Oct 18, 2025 | 08:04 PM
db426's Avatar
db426
Stage I
Default Don’t let it sit
Originally Posted by checkers
So all the trashed Onan RV gen sets, my shed full of trashed weed eaters and leaf blowers don't run because?
Everyone buys 11%+ ethanol fuel?
Ethanol fuel only absorbs water in East Tennessee?
Ethanal fuel only goes stale and brown where I live?
I could go on.
I have read many of your posts over the years and they are mostly on point, was this post serious?
If you let it sit then the ethanol will separate and sink to the bottom. This is the issue in small engines. I used to take them apart and flush out the carbs each season until I started using ethanol free fuel. It will run fine, it’s the sitting that will cause problems.
Old Oct 20, 2025 | 07:29 AM
Goose_NC's Avatar
Goose_NC
I could go on.
Your small engines sit how long in between usage? I run pure gas in my small engines, except my generators. Pure gas for my two stroke small engines. How long did those small engines sit in between usage?
I run ethanol fuel in my generators. I will turn off the fuel and let the carbs run dry before storage. Not an issue with my generators.
Old Oct 20, 2025 | 07:35 AM
FLSTF's Avatar
FLSTF
You realize you're trying to revive an 8 year old debate? Lol
