Vibration
Old May 20, 2017 | 06:29 PM
goose222's Avatar
goose222
Default Vibration
400 miles on my street glide and it has developed a vibration felt through the whole bike on deceleration. Pretty dange smooth on excelleration. Anything I can check before it goes to the dealer?
Old May 20, 2017 | 07:20 PM
sto's Avatar
sto
6th Gear
Default Vibration
My RK does the same. Bike has 1700 miles. I really haven't given it much thought, but if it's uncommon, I'll have the dealer address it at the 5K check.
Old May 20, 2017 | 07:34 PM
lp's Avatar
lp
More than a few people have mentioned this and their dealers of course stated it was normal. Mine does it as well. Not sure I agree it should be normal...
Old May 20, 2017 | 08:08 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Could it be the slipper clutch? It will allow the slipping if your clutch is engaged during deceleration. That may feel like vibration. If you pull the clutch in does it go away?
Old May 20, 2017 | 10:05 PM
mjwebb's Avatar
mjwebb
"has developed"..meaning wasn't there until all of a sudden around 400 miles? 6500 miles on my RK, no such issue exists..smooth and consistent throughout thus far, actually very impressed how nicely it behaves....guess I'd be tempted to put a wrench on anything and everything I could to see if something came loose, if not wouldn't wait until the 1K so just get it in asap..good luck
Old May 20, 2017 | 11:16 PM
goose222's Avatar
goose222
Let's just say I just started noticing it. It sounds like it could have something to do with the slipper clutch.
And when I pull the clutch in and coast it is as smooth as can be.
Old Sep 29, 2019 | 03:06 PM
saddlebag's Avatar
saddlebag
I've noticed this on mine too. Doesn't do it until the engine heats up. Yesterday it was doing it passing down thru 2600 rpm in any gear. Today, it was doing it passing thru 2400 rpm. I thought it might be tranny or primary so today I just revved it in the driveway in neutral. Of course, the rpms decline really rapidly when there is no load, but I'm pretty sure it's coming from the engine. Really odd. Just does it for a couple hundred rpm on decel once the engine's hot.
I'm guessing it has something to do with the computer's fueling calculation once the engine temp rises.
Old Sep 29, 2019 | 03:17 PM
702's Avatar
702
Check your drive belt tension.
Old Sep 29, 2019 | 04:28 PM
saddlebag's Avatar
saddlebag
Does it change much as the bike warms up? If so, should it be checked while hot? Are you thinking too loose or too tight?
Old Sep 29, 2019 | 07:11 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
I had the same issue with vibration and it was the belt tension for me. It was too tight.
