Stage 3 upgrade
Old Aug 29, 2017 | 04:21 AM
paullavery's Avatar
paullavery
Default Stage 3 upgrade
I am thinking about installing the stage 3 kit on my Road King, I have read numerous posts on this site & was just wondering if anyone has done this on an M8 RK & if so what did they think.
Old Aug 29, 2017 | 06:12 AM
Mbogo's Avatar
Mbogo
I had a Stage 3 kit installed on my Ultra - very happy with the results in every respect from clutch feel to power. I love it
Old Aug 29, 2017 | 08:21 AM
petsur's Avatar
petsur
Have stage 3 on my RK. It expands the powerband so it doesn't fall off quickly like the stock M8. I'm sure you've checked out the dyno chart comparisons on the Screaming Eagle site.
Make sure you get the new oil pump if you do. Mine is in the shop for the oil sumping issue.
Old Aug 29, 2017 | 08:22 AM
sixguns's Avatar
sixguns
Im pushing 14k miles on my stage III, no complaints at all. Great power throughout and sounds great too.
Old Aug 29, 2017 | 09:39 AM
paullavery's Avatar
paullavery
All good info, just what I wanted to hear. Roughly what was the cost of fitting ? Obviously here in the U.K. we are not restricted with the EPA regs so will I be ok with a power vision tuner or is it best to stick to the HD tuner on this ?
Old Aug 29, 2017 | 01:15 PM
hattitude's Avatar
hattitude
If you care about your warranty, use the HD tuner until the warranty is up...
If you don't care about warranty, go right to the powervision...!
Old Aug 29, 2017 | 03:19 PM
paullavery's Avatar
paullavery
Fortunately in the UK we are not affected with aftermarket tuners & warranty issues which is why i have tuned the stage 1 with the PV tuner, presumably i'll be able to get a new map from fuel moto for the stage 3 or use the auto tune facility.
Old Aug 29, 2017 | 08:42 PM
Blue Tick's Avatar
Blue Tick
I'm debating the stage 4 on my bike. Currently, I have a stage 2 setup tuned with my powervision. There's no question, use the PV. That crap HD tuner leaves a lot on the table and will not allow the tech/tuner to make changes across the range that they need to make. Warranty wise, if your dealer is worth their salt, you'll be fine.
Also meant to say, I would seriously consider looking at another cam. There's several now making them for the M8's, TTS, Woods, S&S, Tman. Any would be better than the HD cams as well. Those are a weak link as well as HD's tuner.
Good luck.....
Bannana Boat's Avatar
Bannana Boat
If you shop around, you will find there are aftermarket cams that will bolt in the 107" and produce better numbers than the EPA stage 3 kit is producing. I have a stage 3 in my 17 RGS and the numbers TTS and Cycle rama are producing with their bolt-in cams in the 107" are better than mine. SE kits all come with EPA compliant cams. As for the tuner, don't do the SE if you want or need a new or custom map. All they can offer is canned maps that may or may not work with your set-up. According to the pro's on here, it has inferior tuneability.
Old Aug 29, 2017 | 10:47 PM
hattitude's Avatar
hattitude
Good deal, I've always had real good luck with FuelMoto maps....
