Bars
Old Sep 3, 2017 | 06:04 PM
Kyle C Kirk's Avatar
Kyle C Kirk
Default Bars
Thinking of putting Paul Yaffe 1 1/4" Monkey Bars on a '17 Road Glide Special. Wondering if they will go on with the stock configuration of if there's other parts needed to complete install i.e risers, clamps, etc. Any info is appreciated.
Old Sep 3, 2017 | 08:12 PM
SWThomas's Avatar
SWThomas
They'll work but you'll need to extend your wires
and hydraulic lines, based on the height you choose.
Old Sep 3, 2017 | 10:52 PM
Buszzbait's Avatar
Buszzbait
I put on the 14" KST Kustoms Renegades which are a 1 1/4" with all stock wires and hydraulic lines. Nothing extra to buy to make it fit my 17 RGS. About $250 delivered from Dennis Kirt. I almost got the Factory 47 in the 14" and those also install with stock lines..They have a great install video on youtube:
Old Sep 4, 2017 | 03:49 PM
SomeOld Biker's Avatar
SomeOld Biker
This is what I used if you have to extend your wires: wire kit #69200034. The kit was plug and play, no splicing and all wires were same color code.
BTW I went with WO 502 bars
Old Sep 5, 2017 | 11:44 PM
Kyle C Kirk
Thank you for the responses and info.
Buszzbait, did you have to do any changes to risers with the KST bars?
SomeOld Biker, I looked up that wire kit and it says it's for softails not touring. But it worked for you?
Old Sep 6, 2017 | 12:12 AM
SomeOld Biker
Yep plug and play and wires are the same colors.
Old Sep 6, 2017 | 12:51 AM
Buszzbait's Avatar
Buszzbait
No changes to risers at all. The only modification you would need to do is they don't have a hole on the bars where the controls go so you will need to grind out the tab inside of the clutch and brake control. https://youtu.be/Re3vViyB_Lg..it will show it on here.
Old Sep 6, 2017 | 07:40 AM
drc270's Avatar
drc270
Factory 47 14" with wire extensions and stock cables.
Old Sep 6, 2017 | 10:27 PM
AzSteve's Avatar
AzSteve
14" Yaffe bars on my 2017 RGS, no changes other than hydraulic lines and wiring
Old Sep 7, 2017 | 07:23 AM
Ashnic's Avatar
Ashnic
This part# worked on a 17?
