DIY 1000 mile service
Old Oct 1, 2017 | 05:12 AM
  #31
nobodyknowsme's Avatar
nobodyknowsme
Originally Posted by D W K
Easy. I'm not sure if others have The TPMS on them like the CVO but they were down 4-5 lbs each when I scrolled through the display that morning. The ride over was 15 miles or so and I assumed when they completed a service, they would set them correctly. That verses me crawling around adding air. I was riding solo so a coule of pounds dint concern me. The TPMS freaks out when they consider the tires to be too low. The point I was making is I recognized the lower pressures but they didn't even check. It was corrected when I got home.
Thanks for clearing that up. Typical of many dearerships I guess to not go the extra mile. Any Harley touring bike is a PIA to get at the valve stems, my 17 RGS is certainly no exception, maybe worse than any previous. Will be checking both bikes later this morning.
Old Oct 1, 2017 | 07:54 PM
  #32
Uboofer's Avatar
Uboofer
Originally Posted by Oldskewl
I believe a service manual is about $125.00, use the remainder amount left over and make them give you everything you need to do the 1,000 mile service yourself.
Service manual was $60 at my shop.
BillJ
2014-2024 Touring Models
36
Mar 16, 2016 01:27 AM
gintree0
Sep 14, 2013 01:17 PM
Reaper7534
Aug 20, 2013 06:47 AM
aeromass
Oil Archive (no new posts)
Aug 21, 2010 07:55 PM
T_Rob666
Jul 5, 2007 04:45 PM
