The right set up?
Old Sep 26, 2017 | 09:48 PM
Quik's Avatar
Quik
Mine pisses oil on the rear pipe and saddle bag, it started doing it after I installed the HD high flow AC, I've gotten used to it and carry an oil rag in my bag now, I just wipe it off when ever I stop for a break and keep on rollin on 2.
Old Sep 26, 2017 | 09:54 PM
mjwebb's Avatar
mjwebb
was the AC cover overtightened, the pleats crinkled, and notice a gap between the filter element and the back plate at the bottom? I've seen this happen..make sure the breather bolts aren't loose and possibly the o rings not installed correctly..run your finger under the breather bolt casting to see if it perhaps is coming from above..obviously a little overfilling and running hard will cause this to happen as well..good luck
Old Sep 26, 2017 | 09:59 PM
Quik's Avatar
Quik
I've taken it off and reinstalled a couple of times checking all of the above, it's no big deal. I ran a S+S stealth AC for a bit and it did not puke, put the HD back on and it went back to the same.
Old Sep 26, 2017 | 10:11 PM
mjwebb's Avatar
mjwebb
ok, worth a shot..I have the same AC on my 17 RK with no fuss no muss, a friend had the same setup and had the same messy issue you report, noticed the filter was crinkled with a gap, replaced filter and didn't over tighten cover and all is good like mine
Old Sep 27, 2017 | 05:18 AM
T Prescott's Avatar
T Prescott
Since the oil was already leaking I let it go to the lower end of the stick, I checked, reinstalled the AC and torqued it to S&S's recommended spec. to see if it would stop and it didn't. I will will run the bike the rest of the week and weekend and will update. So far it's bone dry...
Old Sep 27, 2017 | 06:02 AM
todd-67's Avatar
todd-67
I don't see how the header could be responsible for blow by out of the crankcase. The two are not related in anyway.
2002eguc
May 26, 2015 01:24 PM
LucyOnBlack
Jun 18, 2012 08:19 AM
bastardsuns
Feb 25, 2009 09:05 PM
2006ultra
Aug 12, 2008 08:06 PM
WARG
Oil Archive (no new posts)
Feb 27, 2008 03:19 AM
