Header Pipe ?
Old Jan 7, 2018 | 04:00 PM
KidGlide's Avatar
KidGlide
Default Header Pipe ?
Looking to replace the header pipes on my FLHRXS this spring. My question, does it make a difference on which pipe crosses over? Are there any performance gains either way?
Old Jan 7, 2018 | 04:42 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
The crossover pipe on the stock bike is bad. So if your going to upgrade to a new header pipe you will have to see what is used, as they may well not all use the stock one. If your looking for one that fits with the stock heatshields I would recommend the one from Fullsac.
Old Jan 7, 2018 | 07:17 PM
berniemc's Avatar
berniemc
Are you saying I wont get a good tune with stock headpipe with cat removed Steve? I already have mine done but waiting on my TTS tuner to come back ...broken pin. Thanks
Old Jan 7, 2018 | 07:38 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
If your going to change the header pipe you should change the crossover away from the stock one. The stock pipe has a "T" joint where the cross over connects and a "T" joint does not flow well. Look inside of the stock pipe and you can see how poorly they are made. Great for production cost reduction, not great for performance. Same goes for the crossover pipe. If your changing, just to change and not looking at performance then it doesn't much matter.
Old Jan 7, 2018 | 07:48 PM
berniemc's Avatar
berniemc
I was just planning on running the stock head pipe for now and I did see how restrictive the head pipe is.I already drilled out the cat so I guess I will try it for now.Thanks
Old Jan 8, 2018 | 10:24 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
If you have done that take a look in the pipe and look at where the cross over sticks in. Some stick into the pipe 1/2 or more while others are less. Take a long grinding bit and trip it off flush with the ID of the pipe is about the best you can do with it.
Old Jan 8, 2018 | 01:47 PM
berniemc's Avatar
berniemc
Thanks for the tip Steve.Mine was flush so that part is good.
Old Jan 8, 2018 | 03:46 PM
KidGlide's Avatar
KidGlide
I am replacing the entire exhaust. I have seen pipes that cross over(guess it would really be under) from the front cylinder and also from the rear cylinder. Which is better, or doesn't make a difference?
Old Jan 8, 2018 | 03:53 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
The pipe orientation and overall design very much makes a difference, this varies greatly based on the engine configuration and power level. Tell us a bit about your bike and combination and we will be able to offer the best advice and info.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 9, 2018 | 08:02 AM
FLSTFI Dave's Avatar
FLSTFI Dave
The Fullsac MX headpipe is very nice, has a nice big round crossover for good flow.
