Finding Neutral
Old May 20, 2018 | 08:39 AM
nobodyknowsme's Avatar
nobodyknowsme
I am on my 3rd Harley with a synchronized transmission and never had a problem with neutral, especially the new bike. If it were me I would probably ride it out and if still an issue at the 1,000 service simply have it checked out. Or take it to the dealer now and let them see the problem. Plenty of people have complained about the effort it takes to pull in the clutch so are you sure you are fully engaging it?
Old May 20, 2018 | 10:02 AM
pioneer11's Avatar
pioneer11
I dunno. The only times I have had trouble with this is when I was really bouncing back and forth between 2nd and 3rd.
Old May 20, 2018 | 03:25 PM
Ludwig von Buzzthoven's Avatar
Generally, Neutral is much easier for me to find on my ‘18 Deluxe when the bike is moving. But i did recently swap our the Stock shift peg with the OEM Nostalgic one (which has a bit more surface area), and its now much easier to find neural when I’m at a dead stop.
Old May 20, 2018 | 03:34 PM
Viking74's Avatar
Viking74
6th Gear
On my 2017 Ultra I had a hard time finding neutral as well. I have 22,000 miles and just changed the shift levers, extended length, now no issue.
Old May 20, 2018 | 03:38 PM
Zerk's Avatar
Zerk
Originally Posted by lyork
t.
I see a few of my fellow riders struggle with it at stoplights occasionally, so you’re not alone
No one is going to jump on this?
Old May 20, 2018 | 05:10 PM
Rickr01's Avatar
Rickr01
I know...Not a good idea to be in Neutral at stop lights. Wasn't mine to question however, I simply wanted to know if other found the newer bikes had a touchy neutral? My 10 Street Glide shifts and finds neutral like butter.
Old May 20, 2018 | 09:11 PM
saddlebag's Avatar
saddlebag
I find Harleys are like acoustic guitars. No two are the same, even of the same model. I've ridden 103s that were smooth and others that shook like mad. Some that pop into neutral with ease each and every time. Others that can not be put there without cutting the ignition.
I think it's a good thing they offer demos. You should definitely demo the one you want before you plunk down the booty. Do this even if you've ridden one just like it before.
I was ready to do a deal on a WG a couple years back until the demo. The anti-stop brakes were a dangerous annoyance, but the idea of having to hold the clutch in at every stop because the bike could not be put in neutral without killing the engine, killed my deal.
Old May 20, 2018 | 09:32 PM
lyork's Avatar
lyork
wow...tough group. Neutral on these bikes is as easy to find as regular gas is at the pump. I still scratch my head why others struggle with it. From shovels, evo’s, twin cams and up...it’s always been between 1st and 2nd and has been easy to find. I had a right shift sporty that was a bit difficult for me, but it was still not bad once I had a bit of seat time.
If you’re having real issues finding it..reach over with your hand and pull it into neutral that way. On the Big custom bikes with forward controls it’s the easiest way sometimes.
Old May 21, 2018 | 08:00 AM
Tony P's Avatar
Tony P
It's not any more difficult than finding it on my twin cam. It's not been an issue for me.
Old May 21, 2018 | 08:12 AM
lp's Avatar
lp
Normal for this guy. I've never had a new Harley in which it was "easy" right from the start to find neutral. That is until it was first broken in. (couple thousand miles)
I'll add that I almost always take off the rear shifter because I don't typically use it, but on this newest bike I put it back on because I found that can you easily get into neutral by lightly stepping on it when you're in first.
