is there an M8 larger capacity oil pan?
Old Sep 5, 2019 | 05:42 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Originally Posted by Keithhu
I could be wrong, but I thought it was Jamie from Fuel Moto saying a larger oil pan wont keep the engine cooler, but I could be wrong.
Nope, That was me. Added capacity does nothing to increase cooling ability. With more capacity it does take longer to get to temperature. The reverse is also true! That is it takes longer to cool down too!. You have to do something to remove the heat from the oil if you want to have it run cooler and a higher capacity does nothing, UNLESS more cooling area is added. The +1 for TC did not add anything for greater cooling so we saw no cooler running from it. Now if they made one with more surface area contact between the oil and the pan itself it may help but capacity by itself will not help cooling overall. Spreading the load over a larger amount of oil will help it to go longer between oil changes as well.
Old Sep 5, 2019 | 05:45 PM
Keithhu's Avatar
Keithhu
Vindication! Thanks...
Old Sep 5, 2019 | 06:03 PM
Thingfish's Avatar
Thingfish
Thanks for the clarification. Never came across that info in the threads I read. They may have also been about aftermarket pans that did try to offer more surface area and cooling fins, but it was 3 years ago so memory isn’t all that.
Old Sep 6, 2019 | 04:36 PM
hellonewman's Avatar
hellonewman
http://www.kandgcycles.com/blog/larg...opportunities/
Old Sep 6, 2019 | 04:57 PM
h7009's Avatar
h7009
Default M8 Oil cooling
Ah a sales ad... Yep, like comments on the internet it must be true. Like several stated above, more oil does not necessarily mean better cooling, it even sates in the "ad" 10-30 degrees...possible/maybe.... No thanks, CSM-H
Old Sep 6, 2019 | 05:27 PM
dave the welder's Avatar
dave the welder
My thoughts are if Harley's engineers thought it needed a bigger oil pan, it would come with one. Just like some bikes come with oiler coolers and some don't.
Old Sep 6, 2019 | 05:35 PM
hellonewman
If that was the case there would be no accessory catalog with mechanical upgrades
Old Sep 6, 2019 | 05:36 PM
hellonewman
Baker (Im sure you've heard of them) did the test and it mentioned surface area and capacity increases cooling. Seemed like a credible and helpful link.
Old Sep 6, 2019 | 05:46 PM
Sierra977's Avatar
Sierra977
Harley SE +1.5 qt oil pan has both increased surface area to better dissipate heat and internal baffling to route btu's from oil to surface fins. It is a well engineered part.
I have one on my 120R and oil tank temps went down 10-12degF. On hot days oil stays below 237F.
I have experience with McLaren engine development engineers (Buick GNX) and Lotus F1 engines (Renault Gordini twin-turbo V6 - Nigel Mansell and Elio de Angelis) and my preference is always for more oil and more cooling.
ETA: If I'm driving, there are only two gauges of interest to me:
Coolant temp
Oil pressure
All the rest are extraneous or distracting.
Old Sep 6, 2019 | 10:04 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
I liked this ad, it clearly explained opportunities for oil cooling improvement in the design of the stock Harley oil pan. Baker added cooling fins, moved the supply and return lines away from each other "for better oil circulation which ultimately led to enhanced cooling", longer hose runs which helped cooling, and improved the baffle; nowhere in the ad does it credit the increase in oil capacity as the reason for the decrease in oil temperature.
