Thundermax
Old Oct 24, 2018 | 05:47 PM
Gtop's Avatar
Gtop
If you ever need some route recommendations. Hit me up
Old Oct 24, 2018 | 05:54 PM
purpledeuce's Avatar
purpledeuce
You can count on it, thanks man!
Old Oct 25, 2018 | 04:50 PM
Vision's Avatar
Vision
I’ve a Thundermax on my Stage IV 2018 Road Glide Special and it does a great Job. As others have stated, you will always get the most out of a Dyno tune, but the TMAX does a pretty damn good job with it’s wide band 02 sensors and dynamic tune. TMAX has fantastic support as well.
Old Feb 7, 2020 | 05:37 PM
Tony58N's Avatar
Tony58N
Stage II
Hi,
What map did you use on your stage 4 with thundermax
Old Feb 7, 2020 | 06:46 PM
hdrider1's Avatar
hdrider1
I've used a Thundermax on highly built Twin Cams and always felt it left a lot "on the table" if you're looking for max hp. It's major short coming is it has no knock retard control ( like the stock ecm) and does not compensate for load -- it's only based on throttle position. No compensation for load/map like the stock ecm. I went with a Power Vision for my M8 vuild and will never look back. Do yourself a favor and get a Power Vision from Fuelmoto with one of their canned maps and you will be very pleased that you did. Thundermax is good for mildly tuned bikes, but for the streetabke high performance builds its a poor choice.
Old Feb 9, 2020 | 02:06 AM
Tony58N's Avatar
Tony58N
Stage II
Default Getting a base map
Hi guys,
have a 2018 FLFBS with a screaming eagle stage 3 kit installed (117 with SE498 cam, 11:1 compression) Screaming eagle high flow air intake, Vance and Hines large radius 2 into 2 exhaust. Have tried maps from fuelmoto and thundermax themselves, but both don’t seem to have the timing quite right. Idle seems off and not crisp, and power is not what it was before the thundermax install. No pinging evident and have clocked about 700 miles since thundermax put in. Can anyone suggest an appropriate base map to start, would think this was a common mod combination. Think my compression and cam are not reflected with previous base maps. Thanks in advance
Tony
Old Feb 9, 2020 | 07:04 AM
Tn.Heritage's Avatar
Tn.Heritage
Originally Posted by Tony58N
Hi guys,
Tony
Tony, I suppose with where you live there are no Dyno's around, that's what you really need to be honest to get it dialed in properly. Hopefully if that's not the case then one of the guys on here can help you out.
Old Feb 9, 2020 | 07:40 AM
Sparky357's Avatar
Sparky357
Exactly the way I see it and everyone chiming in on wide band O2 sensors should know that it is an option for the PV with the auto tune module. All this without needing a notebook computer. The omission of knock control is a big on but I think they’ll probably be fixing that soon hopefully .
Old Feb 9, 2020 | 08:51 AM
hdrider1's Avatar
hdrider1
Hi guys,
Tony
0ther than switching to a PV with a Fuelmoto map, I would suggest that you send a copy of how the bike is running and send to Thundermax. It's a fairly straightforward process to record the bike running conditions and the map parameters with the bike hooked up to a laptop - you can do all this sitting in the garage. Thundermax will look things over, make some changes, and send you a revised map or suggested solutions. In my experience they have always responded via email within 1 day.
With that said, I learned my lesson and now use a PV with Fuelmoto maps.
Old Feb 13, 2020 | 09:01 AM
Max Headflow's Avatar
Max Headflow
Don't need knock control unless you are trying to run stoichiometric at cruise on a production smogged bike. It's there to fine tune cruise that is needed due to manufacturing tolerances. Having it, is not going to make any difference at wide open throttle except that it might trigger randomly and you lose HP.
Since the M8s use knock sensors instead of ion sensing (patented by Delphi), thundermax didn't bother using them?
