Thundermax
Old Oct 23, 2018 | 04:45 PM
Gtop's Avatar
Gtop
Default Thundermax
This winter I plan to have a stage 2 installed on my 18 RKS.
I live relatively close to Zippers so they're an option for my installation. From what I've heard they like to use their Thundermax. Is the Thundermax a solid reliable tuner?
My other option would be to use someone else and another tuner like TTS. Problem is theres nobody close by to me that I've heard of that tunes with it. I'm not opposed to travelling an hour or two if I have to.
just wondering how TTS and Thundermax compare. I'm only going to do a stage 2 and will never go wild in the horsepower game
Old Oct 23, 2018 | 05:04 PM
rdc401's Avatar
rdc401
Call fuelmoto and get powervision with the map for the redshift cam and you will be set for anything you do to your bike and it is cheaper than thundermax.
Old Oct 23, 2018 | 06:03 PM
aviscomi's Avatar
aviscomi
I've ran the Thundermax on my last 3 Harley's and intend on running it on my 2018 RGS when I get around to swapping out cams. IMO it's better than most/all others, just the fact that it uses wide band sensors makes it "leaps & bounds" better than the other tuners.
Old Oct 23, 2018 | 07:24 PM
purpledeuce's Avatar
purpledeuce
I’m running the thundermax and have no complaints. Zipper’s has been a staple in Elkridge for a very long time. It’s money well spent there
Old Oct 23, 2018 | 07:48 PM
dwagar's Avatar
dwagar
I’m running the RS468 cam with a Thundermax, I’m really happy with it.
Old Oct 23, 2018 | 07:52 PM
jayrocker's Avatar
jayrocker
I have own all the above listed tuner from Power vision, TTS , Screaming Eagle Race Tuner and Thundermax they all do the job if properly tuned by a professional. The big difference is find a local dyno tuner that knows the tuner software in your case Thundermax and get them to tune your bike. You will see so many of these arm chair/seat of the pants dyno tunes on here that will tell you what brand they personal own is the best hand down and so on. If you buy a thundermax and have a good dyno tuner in your area you will be super happy with a Thundermax. Hope this helps enjoy the new ThunderMax its money well spent.
Old Oct 24, 2018 | 04:06 PM
Gtop's Avatar
Gtop
Let's say I decide to get my Indy to install a S&S 475 cam, D&D Billet Cat, Stealth air cleaner, and the Thundermax. He had no dyno. Will a canned tune for that combo put it close enough where I can ride it without issue ? Will the auto tune feature fine dial it in even more?
My last two bikes were Evo's so all this electronic and EFI stuff is new to me
Old Oct 24, 2018 | 04:56 PM
purpledeuce
Dyno is always the best option for optimal performance but a canned map will get it close. A couple auto tunes will get it closer still.
Where in Maryland are you? I’m over in the county
Old Oct 24, 2018 | 05:16 PM
Gtop's Avatar
Gtop
I'm in Frederick County.
Old Oct 24, 2018 | 05:22 PM
purpledeuce
Beautiful riding out there, Baltimore County here. We have out sweet spots, but nothing quite like what you get
