Noisy primary
Old Jan 26, 2019 | 06:44 PM
Jackie Paper's Avatar
Jackie Paper
Check your service manual. For the last few years, SYN3 is second choice for primary and transmission. Dealer is thinking $$. What is interesting is there is only a couple dollars difference between SYN3 and Formula +.
​​​​seen $20 difference in an oil change.
Ask them for me if the SYN3 is harder to pour in.
On that new of bike, either should make little difference in sound.
Have not see a M8 owners manual.
Old Jan 26, 2019 | 06:49 PM
Cazador's Avatar
Cazador
Member
The owners manual says to use Formula plus. But the invoice for the service on mine shows that they put Syn3 in it.
Old Jan 26, 2019 | 07:02 PM
albatross's Avatar
albatross
Yeah, I used formula plus and with only 6700 mile, it’s hard to imagine the chain tensioner could be shot. When I have time, I’ll open the primary and see what’s going on. Thanks for the replies!
Old Jan 26, 2019 | 07:11 PM
Cazador's Avatar
Cazador
Member
It's supposed to be self adjusting? Some have said that the new slip transmission maybe causing it to not adjust.
I don't know if that's true or not. Just passing along something that I read. Don't exactly know where I read it either.
Old Jan 26, 2019 | 08:36 PM
Cbyway's Avatar
Cbyway
The few times I thought by sound it needed adjustment, I just HAMMERED it in 3rd gear. Solved.
Old Jan 27, 2019 | 06:46 AM
Jackie Paper
That has been going round since the auto adjust came out. Don't start it on the M8.
Even if it needs to adjust, it probably won't happen for 40-50k and then one step.
My bike at 50k has been adjusted one time and really did not need that. (Is manual)
The auto one is a slightly smaller step. It also has two heavy coil springs in it's base as pre-tensioners that give it the impression it is too tight unless you push pretty firmly. That is why it is quiter then a manual one.
Old Jan 27, 2019 | 07:24 AM
Newfie's Avatar
Newfie
Clutch Pax, had the same problem on my 2017 RGU. They had to put a shim in the clutch pack and that ended the problem.
Old Jan 28, 2019 | 10:32 AM
touchdown's Avatar
touchdown
Formula 1 is cheaper than sys 3
Old Jan 28, 2019 | 12:05 PM
Jackie Paper
That is what I was saying. Guess to much humor?
Old Jan 29, 2019 | 05:30 PM
Stiggy's Avatar
Stiggy
Well it's old (2000 FLTRSEI,) and I know that the tensioners are different ( I've run an M6 since new,) but the oil has always been Wal-Mart 20-50 dino changed out every 5,000 miles ( $2.59 / qt,) and the bike now has 165,000 miles on it with the original chain, clutch, compensating sprocket and clutch basket. The shoe on the M6 is original as well. Oil doesn't seem to be the issue here.
