Noisy primary
Old Jan 26, 2019 | 03:35 PM
albatross's Avatar
albatross
Default Noisy primary
So, I had just finished changing oil on the bike and had it idling while I gave it the once-over looking for leaks. Was on the left side checking around the filter and as was straightening up noticed quite a bit of noise coming from the clutch end of the primary. Sounded like a bunch of nuts in a tin can. Never noticed anything like that on any of my twin-cams but was wondering if anyone had noticed anything similar. Didn’t notice anything unusual when refilling the primary and haven’t had a chance to open it all the way. Bike seems to operate as it should. Thanks.
Old Jan 26, 2019 | 03:37 PM
touchdown's Avatar
touchdown
cam tenchener
Old Jan 26, 2019 | 03:47 PM
Keithhu's Avatar
Keithhu
Originally Posted by touchdown
cam tenchener
He said left side of the bike. The cam *tensioners* are on the right side.
Old Jan 26, 2019 | 03:52 PM
Stiggy's Avatar
Stiggy
I believe he meant to say primary chain tensioner.
Old Jan 26, 2019 | 04:19 PM
lp's Avatar
lp
If those are bad enough you can hear them on the left side of the bike too.
Old Jan 26, 2019 | 05:09 PM
OldMike's Avatar
OldMike
I know Twin Cam Rushmore bikes are particular about which oil is used in the primary.
What oil did you put in there? What about the fill level?
Old Jan 26, 2019 | 05:13 PM
Kingglide549's Avatar
Kingglide549
WTH are you running a bike in for in January?
Its probably shivering!
Old Jan 26, 2019 | 05:33 PM
Harttoo's Avatar
Harttoo
If You put in Syn3 instead of Formula plus.That's it.
Old Jan 26, 2019 | 05:52 PM
Kingglide549
When in doubt pull the cover and look!
Old Jan 26, 2019 | 06:34 PM
Cazador's Avatar
Cazador
Member
The dealership put Syn3 in my primary twice. No problems with it. I am pretty sure that I saw some advertising at the dealership to use it in all three holes.
