M8 Dyno Numbers
Old Nov 20, 2023 | 01:25 PM
  #841
yobtaf103's Avatar
yobtaf103
Originally Posted by Bayou FLHR-M8-128"
This is the latest cam that has caught my attention from a builder "Master Tech Miller" in Australia on YouTube.
A drop in cam designed for the SE 128/131 package makes right @ 150 hp and just over 160 torque along with great low, mid and high. "CR-512".
Now if you have a big bore with high compression of 11 to 1 or better checkout the CR-515.
Hope you can read the dyno chart.
Cam and information below from FuelMoto
This screenshot chart is my buds bike here in UK, 19 Fatboy SE131 Kit fitted & only CR512 & pro-pipe fitted ,PV tuned- noted clutch slip
Old Nov 26, 2023 | 08:05 AM
  #842
H39's Avatar
H39
Here is the reference for warranty-compliant enthusiasts:
2023 Road King Special
131 Stage IV Kit w/ SE Pro High Volume Oil Pump
Arlen Ness 15-spoke inverted series air cleaner
TAB performance BAM slip-on mufflers
SE Pro Street Tuner
124HP @ 5.6K RPM
138TQ @ 4.0K RPM
Old Nov 26, 2023 | 11:00 AM
  #843
Mofo67's Avatar
Mofo67
Currently running an HD EPA compliant 131 in a ‘21 Limited. There seems like a lot of options for cam upgrade. Of course FM suggest the Woods 77X and most every company has a suggestion.
I decided to go with APE Cycle Rama, 483, 512, or 515. After a few emails with Ben from APE, I ordered the 515 from FM. It will probably be January before I have it installed, but looking forward to the upgrade. I will post a list of other upgraded components once I get a little further into the change.
Old Nov 26, 2023 | 11:14 AM
  #844
Bayou FLHR-M8-128"'s Avatar
Bayou FLHR-M8-128"
I had a reputable builder (the Miller tech on YouTube from Australia that uses mostly CR cams) tell me that the 515 was designed for higher compression and to go with the 512 with the SE Stage 4 EPA build....
Old Nov 26, 2023 | 11:29 AM
  #845
Issysportster's Avatar
Issysportster
SE Pro Street Tuner
124HP @ 5.6K RPM
138TQ @ 4.0K RPM
Did the dyno guy happen to give you the AFR chart for the run?
Old Nov 26, 2023 | 11:48 AM
  #846
Mofo67's Avatar
Mofo67
I’ve seen a few videos on Master Tech Miller as well as Those Dyno Guys. TDGs likes the 483 and MTM likes the 512. I don’t think you can go wrong with any of the 3 cams. Cycle Rama actually suggested the 483, but again APE said 515.
Could be wrong, but I think the 515 is a little newer and is not a drop in cam for stock bikes. I’ll post more updates as things progress.
NOTE; Matt @ThoseDynoGuys, actually tuned my ‘12 when I had an issue in Sturgis a few years ago. It was a difficult decision to go against Matt’s recommendation since he did such a great job on my prior build, but we will see.
Old Nov 26, 2023 | 02:03 PM
  #847
H39's Avatar
H39
Originally Posted by Issysportster;[url=tel:21467217
21467217[/url]]Did the dyno guy happen to give you the AFR chart for the run?
Negative and agree I should have asked. Will follow up during my next visit.
Old Dec 6, 2023 | 05:11 PM
  #848
Bayou FLHR-M8-128"
Default GMR 555 Cam in a SE-131 posted today
Old Dec 8, 2023 | 07:51 AM
  #849
cmathison's Avatar
cmathison
Thats the target I'm going after next, when i get around to cracking open my 2021 EGS 107
Old Dec 12, 2023 | 10:46 AM
  #850
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
For those interested we installed an assortment of camshafts in the Screamin Eagle SE 135 crate engine. There is a full article & dyno charts on the FM University website here>> https://university.fuelmotousa.com/article/2045/
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
