Brake Rotor Fasteners
Old May 15, 2019 | 12:10 PM
KrustyKush's Avatar
KrustyKush
Default Brake Rotor Fasteners
A question for any who have removed/replaced stock front brake rotors on their stock wheels. I didn't find anything about this in the manual.
I'm about to put new tires on my RGU. Last time I did this, I left the brake rotors on the wheels while I wrenched on the tire tool. I'm thinking I'd like to remove the rotors this time to allow a couple more inches of room for my mount/dismount bar.
1. If the bolts that hold the rotors on are locktited, was it necessary to heat the wheel to free the bolts?
2. Did you replace any of the fastening hardware? Bolts, springs or bushings?
Thank you
Old May 15, 2019 | 12:41 PM
merlin 2's Avatar
merlin 2
if you take the old bolts out put new bolts in.
Old May 15, 2019 | 01:15 PM
VDeuce's Avatar
VDeuce
Yes, as stated above, if removed they should be replaced. They have dry yellow loctite patches on them already, no need to add more.
Edited: they can be tough to remove, but I would not add any heat due to bearings/seals.
Old May 15, 2019 | 01:22 PM
KrustyKush's Avatar
KrustyKush
Thank you.
I think I'll just leave the rotors on. I did it before with them on, but wanted a little more room.
Old May 15, 2019 | 01:26 PM
fishtale's Avatar
fishtale
Replace with new bolts. Do no heat to remove. Use an air impact wrench and they will come right out.
Old May 15, 2019 | 01:44 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Thank you
Which manual are you using? My manual clearly states answers to your questions.
Old May 15, 2019 | 02:22 PM
KrustyKush's Avatar
KrustyKush
I’ve got a factory manual. I fumbled around with it but couldn’t immediately find the page.
In any case I was pretty sure the factory says to replace all hardware every time.
They say the same about other things, like muffler clamps but most don’t replace those every time.
I wanted to to know what riders are actually doing
Rcox60
Mar 10, 2018 08:29 PM
festy1
Nov 6, 2017 05:49 PM
TwoBlue02
Sep 12, 2016 06:20 PM
steelerdude1
Aug 4, 2015 08:10 AM
car99r
Apr 27, 2006 10:29 PM
