Front Brake Bolts/Rotors
Old Mar 7, 2018 | 08:40 AM
Rcox60's Avatar
Rcox60
4th Gear
Default Front Brake Bolts/Rotors
Why would the wave washers on the rotor bolts continue to brake or come up missing on 2010 ultra Ltd. I put a set of new impeller wheels from a 2017 Ltd on this bike in the summer. In Oct, we took a trip and the left rotor was loose. Had it fixed in Daytona, by the time I got back to pigeon forge, tn it was loose again, but not as bad. Daytona replaced the entire rotor, bolts and all, Pigeon Forge said the wave washers were missing. After speaking to both dealerships, Daytona refunded the $$ I spent inPigeon Forge. Now I hav it back in the shop in Indy, with the same problem, 5 months later. Service showed me the washer broke into pieces when they removed the rotor bolt. Didn’t know if anyone has had the same or similar problem. Any input is welcome. Thanks
Old Mar 8, 2018 | 08:56 AM
grbrown's Avatar
grbrown
I had similar problems with aftermarket rotors and wave washers. I never could get any satisfactory answers as to why the darned things fail and break. I've gone to a different brand now, but it is early days, as far as reliablity is concerned. It'll be interesting to hear what other members come up with.
Old Mar 8, 2018 | 10:31 AM
dawg's Avatar
dawg
Interesting, my rotor bolts don’t use wave washers. Just bolts that hold the rotor on. Looking at a parts fiche for a 2010 FLHTK, I’m not seeing any washers on the rotor bolts either. Is this just an aftermarket thing?
Old Mar 8, 2018 | 11:01 AM
Rcox60's Avatar
Rcox60
4th Gear
No it’s for the floating rotors, honestly not sure if it has to do with impeller wheels that came from a 2027 flhtk. When the wheel was mounted they put the tire on backwards, and puttered around town a little until I could get corrected. This caused my abs not to function, because the sensor was on the wrong side
Old Mar 8, 2018 | 11:16 AM
dawg's Avatar
dawg
Huh, I have HD floaters and still don’t recall a wave washer. I just looked on their P&A site and see the wave washers you are talking about. Interesting that they are disintegrating.
Old Mar 8, 2018 | 12:45 PM
ratpick's Avatar
ratpick
Must be using wave washers to put floaters on those new style rushmoore wheels...? I was wondering how floaters worked on those--doesn't sound like a very good setup
Old Mar 8, 2018 | 03:03 PM
Rcox60's Avatar
Rcox60
4th Gear
It's just the one side each time. But SS Harley in Indy says they will fix it. We'll see
Old Mar 10, 2018 | 08:29 PM
Rcox60's Avatar
Rcox60
4th Gear
Picked up my bike today, sunny, cool, rode it back about the 60 or 70 miles from Indy to home. Advised by the tech that they replaced the left side rotor, all the bolts, spacers and wave washers, as several were bad. They also replaced some bolts spacers and wave washers on the right side. When ask d hey he thought I’ve had so much trouble, he advised that when the rotor was changed and they appaerently overlooked replacing wave washers causing he loose rotor again, that the next dealership when installing wave washers it appears they did not replace the spacers, they feel this will take care of it. We will see, but so far so good, and I let eat on I 65. 2 weeks to spring break for me, just looking for a direction with good weather.
KrustyKush
Milwaukee Eight (M8)
May 15, 2019 02:22 PM
Rickr01
Feb 26, 2018 05:48 PM
mastery
Aug 9, 2015 11:21 AM
barrygreen
2014-2024 Touring Models
May 1, 2015 06:41 PM
terrapin88
EVO
Apr 27, 2010 12:39 PM
