Replacing the clutch on my 04 Harley Electra glide standered any one got any of the turqe specs on the primary cover and the 6 bolts around the basket and what the torque specs for the derby cover thanks for any help
[/left]
welcome from Spartan Country Michigan.
Let me start by saying two things....first be prepared for some sarcastic and smart assed remarks. expect many comments about this....
and second, get the factory service manual and parts manual. All the info you need is in there.
Chain inspection and derby cover screws
84-108 in-lbs (9-12 nM)
Primary Chaincase Drain Plug
36-60 in-lbs
Primary cover
108-120 in-lbs
Primary Oil Capacity
32 ounces
That all being said, if youre looking for the torque specs on those items, dont forget the torque specs on the clutch hub nut, comp nut, and chain tension specs. Also may wanna shim or shave the comp nut whilst youre at it.
