brake rotor quality
Old Apr 26, 2010 | 07:04 PM
terrapin88's Avatar
terrapin88
Default brake rotor quality
I'm getting ready to do a tire change. While I have my wheels off I figured I should change my tired rotors. After a quick online look, I see them going from 40-500 bucks for a rotor. Any experience out there with aftermarket rotors? Who's good and who's not. Price is a factor in my equation, but I don't want to substitute safety so I can save a few bucks. What should I be looking for in a new rotor?
I found these--> http://www.jpcycles.com/product/2400...ement_search=1
That seems to be THE cheapest. Down the page from that I found this one.
Aside from the venting holes, what am I missing that makes this one cost double the first? Do the vented rotors work that much better than stock?
Thanks-
Old Apr 26, 2010 | 11:21 PM
terrapin88's Avatar
terrapin88
I did a little research and now I understand why heat dissipation is important on a bike, so I'm looking for a vented rotor.
Any recommendations on vented rotors?
Old Apr 27, 2010 | 04:48 AM
grbrown's Avatar
grbrown
I've ridden bikes since disc brakes first came on the market. Compared with drum brakes at the time discs were cr*p! One reason is that solid discs don't clear rain water away very quickly, so discs with holes are wise! You can buy factory floating rotors for around 100 bucks each, I just fitted one to the rear of my bike. Doesn't get much better than that and I would prefer them to cheap aftermarket ones. Try some of the discount Harley dealers? (There is a thread over in the Touring forum with popular ones)
Old Apr 27, 2010 | 06:45 AM
Buddy WMC's Avatar
Buddy WMC
Take a look at the Russel 5-shots. Good looking, stainless with black highlighting and hold up well. Been running them for several years and not that pricey considering the quality. Be wary of knock offs. I found out the hard way when the rotor bolt couterbores were too small for the rotor bolts on one set af aftermarkets I bought. Had to turn the rotor bolts down to make them fit. Make sure that you get the correct rotors for your bike. Some rotors use countersunk bolt holes and some are couterbored for the rotor bolts.
Old Apr 27, 2010 | 07:13 AM
I8SMK4U's Avatar
I8SMK4U
I just bought a set from K-C International. $90 for a set of rotors. I like them so far.
Old Apr 27, 2010 | 09:16 AM
xxxflhrci's Avatar
xxxflhrci
Yep, I've been running a pair of those el Cheapo polished rotors for a few years now with no complaints.
Old Apr 27, 2010 | 12:39 PM
terrapin88's Avatar
terrapin88
Thanks for the info guys. I never thought about the venting helping with water. Thats a good point. My rotors are not vented and I think the front is warped. From what I've read, the floating rotors may be a good bet. I'll have to check into those more.
sonar_chris
2014-2024 Touring Models
Feb 26, 2020 09:57 AM
8ntsane
EVO
Jun 3, 2016 09:45 PM
steelerdude1
Aug 4, 2015 08:10 AM
EastBay_Solo
Jan 25, 2013 02:27 PM
scorchedearthpolicy
Wheels/Tires
Oct 25, 2009 08:30 AM
